Another TV Antenna Question/Puzzle - Fiberglass RV
Old 05-28-2017, 02:14 PM   #1
Trailer: '15 17' LD Casita and '17 Tahoe LT
I have a 2015 17' LD. I recently purchased the unit and doing some odds and ends to it. The previous owner took the tv and most of the mount but left the small part that it attached to that is bolted to the underside of the cabinet area on the rear passenger side. It does not have a tv shelf. I can see nothing on top that looks like an antenna so I purchased a stand alone OTA antenna on a tripod to set up outside the unit. Ran the coax to the outside connection of the unit and into the amplifier box that came with the antenna. Worked great. Then started changing the cables around going through the booster in the cabinet, etc. After trying several combinations that worked or just sort of worked, I unhooked the outside stand alone antenna and put it in the garage. I then hooked a cable from the booster directly to the tv and turned on the booster. I get almost as many channels as I did with the stand alone unit although some would fade in and out. I am wondering where the tv must be getting the signals? The only thing on top of the trailer is the AC and the two vent pipes going to the black and gray tanks. Is there some type of antenna that I can not see that may have came with the unit? As it works now, I don't seem to have any use for the stand alone OTA I bought. Any ideas appreciated.
dmad1 is offline   Reply With Quote
Old 05-29-2017, 09:10 AM   #2
Trailer: 2016 ,17ft Spirt deluxe Casita.
The antenna is moulded into the roof behind the air conditioner...
ironbutt is offline   Reply With Quote
Old 05-29-2017, 01:25 PM   #3
You mean where it can't be seen? If so, it works pretty good. I had never heard that. Wanna buy a OTA antenna? lol.
Flooring experiment - Cheap Puzzle Foam Tiles John DM Modifications, Alterations and Updates 7 08-21-2015 09:39 AM
TV antenna question for owners of any brand of trailer rgrugg Care and Feeding of Molded Fiberglass Trailers 12 10-16-2013 03:52 PM
Antenna Question Chris C Problem Solving | Owners Helping Owners 31 03-11-2008 11:05 AM
boomerang antenna question Legacy Posts Problem Solving | Owners Helping Owners 5 03-09-2003 05:07 AM
TV Antenna with Amplifier Question Legacy Posts Problem Solving | Owners Helping Owners 9 11-30-2002 04:05 PM
