Anyone added insulation? - Fiberglass RV
Old 09-06-2013, 09:34 PM   #1
Trailer: Burro 13'. 1982
Montana
I was wondering the best way to block insects, etc from coming in thru the vents behind the refrigerator? I know that silver backed insulation is used all over my Burro.....has anyone replaced theirs or added more? Can I add more in that area and also in my closet? What is that stuff called? Is it the same stuff used in stick homes?
Lfoxmont is offline   Reply With Quote
Old 09-06-2013, 09:46 PM   #2
carlkeigley's Avatar
NE Oklahoma
I can't answer about Bolers but this is a project I've started in mine.
Reflectix from Lowes and floor foam mats from Sam's Club.
Old 09-06-2013, 09:49 PM   #3
Montana
Thanks! Did you block the vent for the refrigerator?
Old 09-06-2013, 09:51 PM   #4
NE Oklahoma
Here I put reflectix in my kitchen cabinet
Old 09-06-2013, 09:51 PM   #5
NE Oklahoma
As far as I know, mine doesn't have a vent.
I have a Magic Chef fridge like you get at the box stores.
Old 09-06-2013, 09:58 PM   #6
Montana
Maybe I'm not using the right term........there is a small register like panel that exhausts something? From the refrigerator......my manual says it needs to be vented. I'm not talking about a vent pipe......just a little register vent that you unscrew off to get access to the back of the refrigerator. Maybe I'll take a few pics tomorrow and post.
Old 09-06-2013, 09:59 PM   #7
Montana
I lik the way this looks!
Old 09-07-2013, 04:49 AM   #8
honda03842's Avatar
Name: Norm and Ginny
Linda, In our Scamp the previous owner had covered the inside of the fridge vent with screening, attaching it to the inside with some kind of adhesive..
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-07-2013, 10:05 AM   #9
NE Oklahoma
Linda, you described it okay. My Snoozy is total electric and
does not have any vents, registers, exhausts. There are a few
drains in the bottom that have screening over them.
Old 09-07-2013, 10:34 AM   #10
Trailer: Fiber Stream
Exclamation Don't block the vent panel with reflectix
Unless your fridge has been replaced with an all-electric compressor unit, it is a 2- or 3-way absorption fridge that silently runs on either propane or electricity. That vent is essential to it functioning, as the fridge uses heat to make cold and operates in a similar manner to a fireplace; a lower vent to suck cool air in and an upper vent to exhaust hot air out. The back of the refrigerator is essentially a chimney. Blocking the lower vent with reflectix will damage your absorption refrigerator.
If you're concerned about bugs then you need to use a mesh screen material attached to the inside of the vent panel. I recommend aluminum mesh.
Old 09-09-2013, 04:47 PM   #11
Montana
Yep......that's what I was concerned about. I went out and looked and I actually have TWO of these vent....screened in sounds good! Thanks!
Old 09-10-2013, 08:35 AM   #12
Trailer: Scamp 13'
Maine
Hey I'd be interested to know what you use to affix the screening - I need to do the same thing.
Mary & The RG
1981 Scamp 13'
2001 Subaru Outback
Brandegor is offline   Reply With Quote
Old 09-10-2013, 11:35 AM   #13
Montana
I'm thinking Velcro.......easy to apply and I can reach behind the refrigerator to press it on.
Old 09-10-2013, 02:24 PM   #14
Montana
Ok.......I decided to use old fine screening from front door panel.......cut it out,trimmed it so it would lay flat on vent.......used Super Glue all around, laid screen in frame and pressed down around edge with pencil. When it's done, I will just snap back into place.
Insulation Chris Jones Modifications, Alterations and Updates 4 07-21-2013 05:35 PM
More Insulation Loren G. Hedahl Problem Solving | Owners Helping Owners 18 04-23-2013 07:41 PM
Insulation Brian Tin Problem Solving | Owners Helping Owners 12 11-02-2010 08:02 PM
Insulation Rick T Problem Solving | Owners Helping Owners 8 03-22-2009 06:56 AM
Insulation Willie Brown Ft. Langley B.C. Rallies 0 12-31-1969 07:00 PM
