Anyone know how to fix a saggy roof in a Boler??? (around roof vent) - Page 2 - Fiberglass RV
Old 01-27-2012, 08:39 PM   #15
Camilla's Avatar
Trailer: 73 Playpac
Kentucky
I just had a saggy roof fixed in my Playpac and they did a great job in Tennessee. I had more than a sag- ill bet it came down a good six inches. Anyway they jacked it back up and used a piece of plywood and glassed it all back. Can't even tell.
Camilla is offline   Reply With Quote
Old 01-28-2012, 03:40 AM   #16
Trailer: 19' Scamp
Nebraska
I am guessing a combination of heat and pressure would help remove the sag..
Being an archer for many years I have repaired a number of fiberglass bows using a blow dryer and pressure.
You are dealing with a much larger animal here but if you can get enough heat to it without burning it, while forcing it back into position, then holding it in position while it cools, you should be able to help it..
However that doesn't mean it won't happen again, and some form of reinforcement would help the long term.
Earl E. November is offline   Reply With Quote
Old 01-28-2012, 06:41 AM   #17
As said, everyone has an opinion and this is mine...
I would NOT put wood on a roof... even if fiberglassed. We've read too many stories from Trillium owners with window problems due to rotten wood framing... and that's on the sides. The roof takes the brunt of rain/snow and you will be drilling holes in whatever you use as a spacer.
Perhaps a wood composite like Trex or other brand that's used for home decks would be a better idea? It wouldn't need to be fiberglassed... just sealed with proper materials.
As I said, my opinion only... YMMV
Old 01-28-2012, 07:46 AM   #18
I herd a lot of people with this same problem.
When I do the restorations on my bolers
I use two L shape pieces of metal and run both down each side of the bump on the boler
And than two flat pieces on ether side of the fantastic fan.
(I have the metal painted with por15 before install)
Than after they are set where I want them I fiberglass them in so 1 can't see them and 2 helps with more structure
Works great and you don't even see them after
Hope this helps
Siris
Siris is offline   Reply With Quote
Old 01-28-2012, 09:32 AM   #19
LukeP's Avatar
Iowa
Hope this helps
Siris
@Siris, to clarify - you're running 2 L pieces lengthwise, then flat pieces widthwise on each side of the fan opening? Where do you find L shaped pieces that fit, or do you have the means to fabricate them to fit? My roof lines weren't at exactly a 90 deg angle.
I wonder what the newer Scamps do to reinforce the roofs to support roof A/C units... maybe something similiar to what you're doing?
LukeP is offline   Reply With Quote
Old 01-28-2012, 10:11 AM   #20
Ya that's exactly how I do it
Any local metal fabrication place would
Have the metal
And
The metal I use I can bend by placing on the two points and a hitting it with a hammer To split it wider
As well it will bend some what for the curve of the boler
I use a two part urethane adhesive to secure it down befor the fiberglass is applied
Costs around 70 for the mod but well worth it
Old 02-07-2012, 03:54 AM   #21
Trailer: scamp 13
nice work.
Old 02-08-2014, 05:56 AM   #22
Trailer: 13 ft Boler 1986
we had a serious ice and snow collapse a few years ago and wound up with a saggy roof. We had also installed a FantasticFan (our opening was also in the middle) which made things worse. We braced the roof back to it's original shape, had a local shop bend 3/8" square aluminum rods to follow the roofline, with flat tabs attached to each end at an angle to fit the roof bump. They were installed width-ways across the roof on each side of the fan, and bolted through to matching tabs on the outside. We painted the outside tabs and the inside bars just don't show up.
We had our choice of installing them inside or outside. Because we are both short, we installed the bars inside to avoid having to do any fiber-glassing, but for you that would be the obvious way to go. Simple, inexpensive, work great and we've had a tremendous amount of snow this winter in southern Ontario so they've been well tested over the past four years.
Vivian L is offline   Reply With Quote
Old 02-08-2014, 06:18 AM   #23
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
Hi I like the idea, do you have any pics of the process? Sounds like something I want to do to my Boler before I go too far with the interior.
Rick
Hope this helps
Siris
Rick Mooyman is offline   Reply With Quote
Old 02-08-2014, 06:59 AM   #24
Rick
Siris come back! Last Activity: 08-29-2013 07:14 PM
Old 02-08-2014, 07:01 AM   #25
Manitoba
Ya I noticed that after I posted my reply guess I should see how old the post are before replying,
Rick
Old 02-08-2014, 07:19 AM   #26
Rick
Well, we need to encourage folks to come back. IMHO there's no harm is posting to an old thread, it's just that questions asked might not be answered. But, maybe someone else can!
Old 02-09-2014, 06:25 AM   #27
Manitoba
I often wonder why people would leave and not come back. Most don't even say goodbye when the leave. LOL
Old 11-16-2014, 10:16 AM   #28
Borden's Avatar
Name: Borden and Carole
Originally Posted by WildBirder View Post
Does the trailer still have the support at the side of the kitchenette? I've seen this removed and cause sagging.
Agree check this out first we have supports on both sides of kitchen counter.
1978 Ontario made Boler
boler
Boler 9"x9" Roof Vent Wanted Dave Mc Classified Archives 3 06-29-2011 09:17 PM
a new roof vent cover for my old Boler? Rick G Care and Feeding of Molded Fiberglass Trailers 6 08-21-2009 09:14 PM
looking for original boler metal roof vent Roy Massen General Chat 3 08-13-2009 11:33 AM
boler roof vent installation charlenep Problem Solving | Owners Helping Owners 1 05-24-2009 09:14 PM
Replacing ~9" roof vent in Boler Raya Care and Feeding of Molded Fiberglass Trailers 34 12-16-2008 07:01 PM
