Anyone know what to use to remove black tar from roof? - Fiberglass RV
Old 10-22-2008, 09:26 AM   #1
Tim Wood's Avatar
Trailer: 2006 17' SD Casita
NY
Just got this Horizon camper and I've been working on it for about 3 days now. Anyway I have tar up on the roof, a previous owner probaby had a leak around the vent or the seam or both. I would like to remove as much as possible and fix it right. I have been using a putty knife and its coming but slow. I'm probably better off waiting until hot weather but that's going to be a while here in NY. Can anyone think of anything I can use without harming the fiberglass ? Here is a picture of the roof
. Thanks,Tim
Old 10-22-2008, 04:51 PM   #2
Would a hair dryer help to heat the tar rather than waiting for hot weather? Once you get absolutely as much off as you possibly can, use Bug and Tar remover... found in the car care products aisle at any autoparts store. I use Bug & Tar remover on my tug and it comes off pretty easily and the tug has a clear coat over the paint (follow the directions!).
Old 10-22-2008, 05:28 PM   #3
Tim Wood's Avatar
NY
Donna, We must be on the same wave length, as I was just thinking about a hair dryer today. Some of it around the vent I'm peeling off with a putty knife, but I'm thinking a hair dry would be just the ticket. I'll keep ya posted thanks the suggestion I appreciate it. Tim
Old 10-28-2008, 09:28 AM   #4
Tim Wood's Avatar
NY
This is just an update on the tar removal on my trailer roof. I bought a new heat gun on Ebay and got it yesterday, so today I tried it out on the tar. Its working really nice, and Donna's idea about using tar & bug cleaner once most of the tar is peeled away is going to work great also. (Thanks Donna ) I don't preach using a heat gun for anything on a trailer, but I used it sparingly and on the low setting. Being a professional firefighter for 32 years (retired now) I've been to my share of fires started with a heat gun. I just thought some of you would like to know that its working and you could probably use a hair dryer like Donna also said. I'm pretty sure the little leak that's there is probably from the vent flashing that attaches to the roof. Its hard to believe that it did leak with all the goop thats around that vent. Tim
Old 10-28-2008, 10:29 AM   #5
Jake Jacobson's Avatar
Trailer: Scamp 16 ft and Trillium 4500
Glad to hear it is working Tim.
Looks like the PO simply dumped a can of tar on the roof to try to fix the leak. Amazing what people will do to abuse their trailer.
Now of course you have to post an "after" photo.
Jake Jacobson is offline   Reply With Quote
Old 10-29-2008, 06:17 AM   #6
Tim Wood's Avatar
NY
Jake, I will take some after photo's probably in the spring, as today the high is going to be around 38. I saw my first snowplow going up the road yesterday, we got a few inches of snow. I have the camper in the barn and its not heated, so I will do most of the roof work in warmer weather. Thanks, Tim
Old 10-29-2008, 07:09 AM   #7
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
I got it off the side of my wifes car using Coke and aluminum foil. I have no idea where I heard that it worked but it did.
Scott S. is offline   Reply With Quote
Old 10-29-2008, 05:13 PM   #8
Tim Wood's Avatar
NY
I have heard about coke working on things like tar, but where does the foil come into it ? Tim
Old 10-29-2008, 05:20 PM   #9
Roger C H's Avatar
Talking
In the old days of chrome bumpers, we used to remove rust from bumpers using Coca-Cola. It's the acidity in the coke that does it. I guess vinegar would probably work as well, for rust that is.
BTW, looking at the picture of your roof it looks like there are water rings or high water marks. I would check if the roof is concave and if it is you may have to add something to the inside to restore its bow so that water will drain off.
I also notice the luggage rack. Maybe the PO carried something heavy up there or at least heavy enough to cause it to sag.
Or maybe a water leak around the vent caused rot in the plywood under the skin. I would think that that should be repaired before taking it back out in the weather.
There is a discussion somewhere on this website about that problem.
Old 10-30-2008, 06:09 AM   #10
Tim Wood's Avatar
NY
Roger, There is a slight sink but not where the rack is. This will be in the barn until I get the roof fixed. I first have to get the tar off, then pull the fantastic fan out, so I can see better what's going on. I know when I talked with the po he told me they had a heavy rain for a couple of days . That was one day before I picked up the camper, and I didn't notice any leaking then. So its possible the trip home may have loosened up something around the vent. Tim
There is a small sink spot between the vent & rack.
Old 10-30-2008, 11:43 AM   #11
Scott S.'s Avatar
Manitoba
you just move the coke around the tar and I guess it's like a chemical reaction.... the tar desolves and you just wipe it off with rags after that. I folded the foil a couple of times down to about a 5" x 5" pad.
Old 10-31-2008, 08:53 AM   #12
Coke and foil - that's a new one on me!
Tim, I've never heard of a Horizon BTW - what does it look like?
Old 10-31-2008, 09:06 AM   #13
Tim Wood's Avatar
NY
Jake, I posted a couple of pics on the General Chat - Horizon Camper under rehab thread. And also a couple of the inside too. This camper is a molded fiberglass and was made for the state of Arizona Fire Safety Offices. I have since talked to Horizon who make stick built campers and they said they made about 100 of these. I have never seen one like it either, I think once I'm done with some work/mods it will be a nice camper. Tim
Black Roof Stains Tamid Problem Solving | Owners Helping Owners 1 04-26-2010 07:32 PM
Fiberglass roof replacement of rubber roof Scott Kominkiewicz General Chat 1 08-16-2007 07:13 PM
How to remove black spots on exterior???? LeeAnne Care and Feeding of Molded Fiberglass Trailers 10 05-14-2007 09:04 AM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
Fiberglass roof replacement of rubber roof Scott Kominkiewicz Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
