Asbestos - '74 Boler heater? - Fiberglass RV
Old 08-14-2016, 08:56 PM   #1
I can't seem to find any info relating to this concern. I finally tore out the old broken heater in my 1974 Boler. The fibrous material around the heater itself looked like asbestos. And I'm nervous that the fibrous material that remains in the heater space is also asbestos. It is beige paper-like material that lines the entire space. I sealed it up for now but I'd love to use the space for a book shelf. Anyone know what this stuff is? I'm in Ottawa, maybe I can get a sample tested somewhere?? Thanks so much.
TBirdy is offline   Reply With Quote
Old 08-15-2016, 03:01 AM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Asbestos is not harmful in a static state, only when it gets to be air born. If your going to pull the rest out use a good resperator and wet the area down so any fibers don't float and bag it up. No idea of where you would legally get rid of it or tested in your area.
Borrego Dave is online now   Reply With Quote
Old 08-16-2016, 06:16 AM   #3
Borden's Avatar
Name: Borden and Carole
Often rock wool is used and it looks like but is not as harmful, or heater was the safer type of insulation
1978 Ontario made Boler
Old 08-16-2016, 08:01 AM   #4
fusedlight's Avatar
Trailer: 16' 1998 Scamp
What the previous poster said... wet it down and remove it. If you're especially paranoid, mix some white (ie. Elmer's) glue into the water and let it dry on the paper. Where a mask. Remember that it's pretty much prolonged exposure to short asbestos fibres that cause problems. It's probably NOT asbestos anyway. I have heard of schools going into lockdown when they discover they have a mineral specimen of asbestos in a collection. That's plain nuts.
fusedlight is offline   Reply With Quote
Old 08-17-2016, 10:01 PM   #5
Borden's Avatar
Have seen a house not sell over slate tiles, thought was they were asbestos but in fact compressed rock fibers and do not burn either but are not as harmful. Have installed the slate tiles great if you leave them alone will last almost for ever.
Old 08-18-2016, 06:23 AM   #6
Borden's Avatar
If you have a boler with a Coleman furnace as we had it will not be asbestos. The Atwood was a close fit. Used a small lift platform under base of furnace hole is horizontal instead of vertical so some body work used left over body cutout material to fill hole. after -gelcoat work it really does not show. The new Atwood unit just turn on switch and set temp and it is going. Wish we had changed ours years ago.
boler
asbestos Clancy Meyerhoeffer Problem Solving | Owners Helping Owners 10 04-10-2017 06:33 AM
Asbestos? Randy J. Problem Solving | Owners Helping Owners 3 08-18-2016 06:12 AM
Terracotta Radiant Heater, Instead of a catalytic heater Adrian W General Chat 13 06-05-2011 02:14 PM
Trillium 75 Duo Therm Heater Asbestos? Kirsten M Problem Solving | Owners Helping Owners 1 05-20-2009 09:33 PM
Mr. Heater Buddy Portable Propane Heater Legacy Posts Problem Solving | Owners Helping Owners 16 08-03-2003 12:01 PM
