atwood lp gas protector beeping - Fiberglass RV
Old 08-07-2018, 03:10 PM   #1
My LP protector was just fine yesterday while I worked my Trillium. The green light was on and flashing,,no beeps. Now when I have shore power on from the house, like yesterday, the green light comes on, then flashes, then goes amber, then beeps, as if there was a leak. I hit the test buttton, red light comes on, beeps louder, then when I release, the green light returns, then blinks, then amber again, and back to the same situation. There is propane in the tank but pretty low...could that be it? The burners on the stove light fine. No smell of gas at all in the egg.
the protector is 9 years old...does that mean it should be replaced?
Thanks, Lloyd
lloyd cicetti is offline   Reply With Quote
Old 08-07-2018, 03:42 PM   #2
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
Thanks, Lloyd
They do have a limited life span. I’m not sure about the model you have, but that sure sounds like an “end of useful life” indicator/alarm. At 9 years of age, yes, it should be replaced.
Old 08-07-2018, 04:44 PM   #3
There is a material inside the detector which degrades over time. It is necessary to have the detector work. As soon as you install the detector and hook it up to power, the material begins to degrade.
You need a new detector.
Old 08-07-2018, 05:08 PM   #4
John in Santa Cruz's Avatar
Mid Left Coast
the one in my 2014 failed, stuck an identical (new) replacement unit in, hasn't beeped yet except for 'test' mode...
Old 08-07-2018, 05:26 PM   #5
You also need to do maintenance. Vacuum the face plate and wipe with a damp cloth.
Old 08-07-2018, 06:36 PM   #6
just ordered a new Atwood dectector from Amazon....it was actually 10 years old when I looked at the back of it. The orange light was on, which I found out means "replace". Thanks to all of you for the advice...I am very happy knowing it will be new. Can't mess with things like that. Thanks again.
Old 08-07-2018, 06:39 PM   #7
When I replaced mine, there was a sticker on the back with date it was made. I had the RV shop call the distributor which is how I learned that the clock starts when you hook it up to electricity. I'd write the date you install on the back and on the instruction manual.
Propane Alarm Beeping Jude Problem Solving | Owners Helping Owners 7 12-27-2018 07:18 PM
Propane detector keeps beeping! Vfarsch Problem Solving | Owners Helping Owners 60 05-28-2017 07:25 AM
atwood gas water heater Snowberry Modifications, Alterations and Updates 19 04-11-2016 02:40 PM
Bumper protector Alistair Camelford Towing, Hitching, Axles and Running Gear 16 12-22-2008 02:17 PM
