Auto start on SMEV stove not working - Fiberglass RV
Old 12-13-2010, 06:46 PM   #1
DannyH's Avatar
Trailer: 1976 Scamp 13 ft "Siesta"
I just finished installing all the propane and checking for any leaks. It went fine and I didn't have to much problems except redoing on long line that I bent incorrect. The first thing I tried was the SMEV stove. I have the sink/ stove combo that was on another trailer awhile ago (I think he was re-doing the insides and selling the trailers.) I noticed that each burner has a projection that looks like it should be a self starter for the burner, but I tried holding it down, turning all the way, each way, and still no spark. I didn't know if anyone had one of these units and could set me straight on how to do it, or what's wrong. I didn't see any indication that it need a power source hooked up. Thanks
DannyH is offline   Reply With Quote
Old 12-13-2010, 07:25 PM   #2
DannyH's Avatar
Here are a couple images of the stove
1st one is top shot of unit
2nd one is showing part that sticks out, that I think is spark starter
3rd is showing bottom of one burner and wires going to spark starter.
Old 12-14-2010, 05:24 AM   #3
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
I am just guessing, but it looks like you should turn on the propane with the knob and then push down on the knob to get your spark.
Bill K
Old 12-14-2010, 08:08 AM   #4
Raz
Raz's Avatar
Vermont
Hello Danny, We have a dometic which I think is SMEV. To ignite a burner you rotate a knob while pressing it in and then press a rocker switch to activate the ignition. The knob must be pressed for a few seconds until a safety thermal couple is heated up otherwise the gas shuts off. The installation manual doesn't mention it but the unit does require 12v. for the ignitor. From your picture I don't see a piezo electric ignitor so I would bet you will need a 12v. connection. Raz
Old 12-14-2010, 09:24 AM   #5
DannyH's Avatar
Raz, If I need a 12 volt connection, I'm not sure where I would install the wires. I can't see anyplace on the bottom were they would be placed.
Old 12-14-2010, 10:00 AM   #6
Hi Danny,
I don't believe your cooktop has the starter feature. I have an SMEV cooktop with the 12v starter and it actually has 2 projections up by the burner. One that looks like yours and another white one which is where the spark arc comes from when pressing the igniter button.
I'm guessing the one you see is some kind of thermocouple designed to keep the gas from flowing for too long if the burner isn't lit. Looking at your pictures it appears that it's connected to the gas valve which makes sense.
Russ
RussL is offline   Reply With Quote
Old 12-14-2010, 10:55 AM   #7
Raz
Raz's Avatar
Vermont
I should have looked a little closer. I think Russ is correct. Time to by an aim-n-flame. Raz
Old 12-16-2010, 07:12 PM   #8
DannyH's Avatar
RussL, you are correct. I looked at the instructions again and noticed that a spark starter button would be next to the two burner button, which I don't have. When I did start it, I did notice you had to hold the burner button down until it got warm, so the projection being a thermocoupler is correct. Thanks for the help. I'm not to bummed out as I got the unit cheap.
Old 12-21-2010, 06:45 PM   #9
Trailer: 1970 Campster
Dometic, a Swedish company, purchased the Italian manufacturer SMEV. The SMEV stoves are now used in some Airstream models. You could try contacting Dometic for support or an RV repair shop that services Airstreams. An alternative is to contact a marine service shop as these stoves were originally used on boats. Good luck!
Lisa H. is offline   Reply With Quote
Old 12-21-2010, 10:43 PM   #10
IllAnnoy
I think what you are looking at is the flame sensor.
Piezoelectric [igniters are optional], but the SMEV is Italian made and meets Euro standards.
Much more intense and efficient.
Here is a picture of the one we installed in "Shelly" {one of our rehab projects}.....
Furnace doesn't start ThomasE Problem Solving | Owners Helping Owners 16 10-13-2009 01:22 PM
SMEV stove/sink combo eBay seller problems RogerH General Chat 10 05-17-2009 10:55 AM
how will I start a fire? Flygal General Chat 37 08-30-2008 09:03 PM
Jump-it, Start-it Bigfoot Mike Problem Solving | Owners Helping Owners 4 09-06-2006 01:18 PM
SMEV stove/sink combo eBay seller problems Chris B Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
