Automotive Paint over Gel Coat Problem - Page 2 - Fiberglass RV
Old 01-31-2014, 12:06 PM   #15
This is what I have used to strip bottom paint off my boat.
Klean-Strip GAF354 Fiberglass Paint Stripper
A milder citrus stripper is available at the hardware stores.
READ and follow instructions for these products.
I rough sand the painted surface to break the skin and apply the stripper. Let the stripper do the work as soon as stripped area wash to decontaminate the surface.
Have you tried using a straight razor blade and scraping the paint off instead of sanding it off? In areas where paint isnt stuck well it flakes off easily. Change the razor blades alot.
Old 01-31-2014, 12:31 PM   #16
David Tilston's Avatar
Originally Posted by D White View Post
Captain Lees for fiberglass...or aircraft stripper for fiberglass
Any idea where, in Canada, I can find it? Or, is there a web seller that ships to Canada?
Old 01-31-2014, 01:22 PM   #17
Trailer: Escape 5.0 TA
W. Mass
A few things.
Need lots of rags
We used to use plastic Bondo spreaders for scraping
Still need to sand some when done
padlin00 is offline   Reply With Quote
Old 02-01-2014, 05:45 AM   #18
Ice scrappers work well too... at least for removing silicone (GAG) and flaking paint. Just don't gouge at the fiberglass.
Old 02-04-2014, 08:12 PM   #19
BillE's Avatar
Trailer: 2016 Scamp 13 Deluxe Birch w/front dinette
Wisconsin
Could be just me
Originally Posted by Str8781 View Post
These posts confirm a lot of my thoughts. I would say that I have an orange peel finish with some curtains. Plus, I always knew that the gravel guard on the front window had been painted, but I assumed that the PO had stripped it down to repaint and then put up a decorative stripe (left over from the Scamp Decal along the side). But I can now clear as day see the old Scamp decal under the paint and new stripe. So that probably confirms how little prep the PO put into the paint job.
It would drive me crazy everytime I looked at it....maybe it's just me...it's a 13 ft so not much area...sand out and buff (or take to a body shop and ask them)...even if it was $800 to do it...it would be worth it to me not to look at it every time I camped.
BillE is offline   Reply With Quote
Old 02-04-2014, 08:24 PM   #20
Around here, $800 would be cheep for an auto body shop. More like $2000. But I could be wrong. I am fond of the idea of using a two part paint that is basically a thin gel coat. I expect to spend about $800 on just the paint.
Thankfully, my neighbor, who loves to paint, says if I do the prep, and buy the paint, he will paint my trailers for me.
paint
Automotive paint ok? Yamaha_gurl Problem Solving | Owners Helping Owners 1 04-27-2011 11:21 AM
Gel Coat Scammers Strike Southern California RVers Ken C General Chat 6 06-23-2009 07:57 PM
Bigfoot gel coat Ralph W Problem Solving | Owners Helping Owners 4 05-05-2009 01:30 PM
Gel coat protection GeorgeR Care and Feeding of Molded Fiberglass Trailers 18 03-20-2008 10:59 PM
Gravel Guard to Protect Lower Gel-Coat/Painted Surface Joseph Olajos Problem Solving | Owners Helping Owners 12 05-31-2007 08:23 AM
