Awning handle mount problem on Scamp - Fiberglass RV
Old 01-03-2019, 12:10 PM   #1
Massachusetts
I have a Scamp 13 with the Fiamma awning factory installed. I am wondering if anyone has installed the 2 brackets that hold the awning crank handle in place inside your Scamp. Reason I ask is that, I noticed that the brackets fit extremely tight to the handle when snapped in place.
Before I installed the brackets I attached one to the handle to check the fit and removal. I found that I could not remove the bracket unless I used a small flat blade screwdriver to force the bracket off the handle. My concern is that trying to remove the mounted handle would rip the brackets off the wall. Has anyone else found this to be a possible problem?
Lockman is offline   Reply With Quote
Old 01-03-2019, 01:59 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
I used a socket bigger than the recess (from a wrench set) and a hammer to do a slight "percussion adjustment" to widen the groove a tad.
Charlie Y
Old 01-03-2019, 04:26 PM   #3
Massachusetts
Charlie,
What size socket did you use, and did the brackets stay to the adjustment?
Was this a Fiamma type device you were working with?
Jack
Old 01-03-2019, 06:15 PM   #4
tractors1's Avatar
Originally Posted by Lockman View Post
Charlie,
Jack
This was in 2006 so I don't recall the size. It was a Fiamma on my new 17LD Casita; don't recall it being an issue thereafter. Then they were a stamped steel part, so no springback involved.Don't know if Fiamma still uses that or an extrusion these days.
Charlie Y
Old 01-03-2019, 07:25 PM   #5
Massachusetts
Charlie,
The new units are made of a heavy plastic material and I would think that approach is not possible, they might break in two.
Jack
Old 01-03-2019, 08:04 PM   #6
tractors1's Avatar
Yup. Don't know Scamp layouts, but you might consider a PVC pipe to stick parts into; then a velcro strap to tie back the long ends. Wound up doing that in my Casita closet as I needed the old spot to relocate my fire extinguisher.
Charlie Y
Old 01-03-2019, 10:48 PM   #7
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Charlie, The new units are made of a heavy plastic material and I would think that approach is not possible, they might break in two.
Jack
Might try using a heat gun or hair dryer to heat it up some to spread it a bit.
Old 01-04-2019, 02:01 AM   #8
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Those plastic brackets are pretty substantial. We've had them in use for over 10 years with zero problem. I can imagine that an unmounted bracket would be extremely hard to remove by hand. It takes a lot of force to remove the handle from a mounted bracket and it will bow the handle along its length somewhat before it pops out. But, it won't hurt the handle and it won't break the bracket. Now, as far as ripping the bracket off the wall, that would be dependent on your mounting hardware. They should be screwed into the fiberglass.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 01-04-2019, 08:25 AM   #9
My Scamp is a little different as it has two twin beds installed.
I put the clamps for the rafter and handle along the side of the left bed and if the clips as closer together and more of the handle is sticking out I can grab it and easily pull that side free and then the other end.
Leave yourself some room for a grip and leverage and you should be good to go.
Old 01-04-2019, 11:50 AM   #10
Trailer: 2000 17' Casita Freedom Deluxe...Tow vehicle 2015 Toyota Tacoma Dble Cab V6 Prerunner
I went to Home Depot and got a couple of brackets for brooms... worked great
Id attach pictures but we have since sold the trailer
alan H is online now   Reply With Quote
Old 01-04-2019, 06:12 PM   #11
Trailer: 2016 -13' Scamp
Massachusetts
We just hang the pole from the top of the bulkhead, just to the left of the bathroom door and to the right of the stove. There is a little lip on the divider that holds the pole in place. It has never fallen down, despite some rough roads.
herons is offline   Reply With Quote
Old 01-09-2019, 01:14 PM   #12
Trailer: Scamp 19
We replaced our original '95 awning with a Fiamma in December of '17. The original awning pole was attached to the door frame behind the bi-fold door. I replaced the single bracket with both brackets from the new awning. Like others have stated it was moderately difficult to remove the new pole for a while, but with time it has gotten easier.
lijMichael is offline   Reply With Quote
Old 01-09-2019, 02:19 PM   #13
Massachusetts
Hey Michael,
I just to-day installed the brackets and submitted a follow up new thread.
As you said "but with time it has gotten easier".
I am sure I will find that also. Thanks for your input.
Jack,
awning, scamp
Battery problem or system problem? Uplander Problem Solving | Owners Helping Owners 4 06-01-2015 04:39 PM
Relacement awning fabric problem Janb313 Problem Solving | Owners Helping Owners 7 04-04-2013 06:06 PM
Special awning mount jrnutpaul Modifications, Alterations and Updates 15 12-18-2006 08:38 AM
Another Awning mount jrnutpaul Modifications, Alterations and Updates 0 11-06-2006 06:53 PM
Horizon awning problem Legacy Posts Problem Solving | Owners Helping Owners 5 05-20-2003 08:06 PM
