Awning Sockets and Curves - Fiberglass RV
Old 05-18-2013, 11:55 AM   #1
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Just an FYI for those of you who may want to figure out a way to work the curves, attachment of sockets to roof top and a bag awning on your little trailers. This is what I use instead of the ball and socket flat plate that comes with most bag awnings roof mount. It's a bathroom shower head holder (use one on each end), I found the angle is good and the ball fits in perfectly. I put rubber under the plastic socket to help hold. You could also use VHB tape.
D Davis is offline   Reply With Quote
Old 05-18-2013, 01:24 PM   #2
Diane posted this in response to my question to her about installing a bag awning on our Uhaul. We figured 7' would be the maximum length to use because of the roof curve. I later remembered that when I installed one on a popup camper that there are ball sockets that the end rafters hook into. Now that's easy to do with a flat vertical sided trailer, but I can't see how to make them work on our Uhaul as the awning has to be mounted far enough up the roof so to clear the door. A rollout awning would be nice, but the shortest that we can find is 8' and that is too long unless it sticks out in midair on the ends. Also I'm not sure if that can be mounted so as to work properly. I think we're going to have to go with a rope & pole awning, and probably a custom made one at that. Anyone had any success with this?
mary and bob is online now   Reply With Quote
Old 05-19-2013, 10:02 AM   #3
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
I stitched some sockets out of heavy webbing-made a small pocket- and then stitched them to the awning where the rafter poles landed under the awning. That way I didn't have to attach sockets or anything to the body of the trailer but kept the rafter poles of the awning in place when it was deployed. Also, when rolled up everything fit nicely inside the bag. Just returned from a trip to the southwest where the awning survived some pretty good winds. More than one way to skin a cat.
Reid Larsen is offline   Reply With Quote
Old 05-19-2013, 11:01 AM   #4
Reid; that's a good idea. How far up the roof is your awning mounted, and does it move at all when traveling due to wind?
Old 05-19-2013, 11:20 AM   #5
The awning rail is about 6" above the door. I did notice that the awning bag flopped up above the rail instead of hanging down sometimes when we had been traveling on rough roads, crossing cattle guards or in high winds. I ran a screw through the rail and into the awning spline front and rear and other than flopping up occasionally ( maybe twice on a three week 2500 mile trip) the awning stayed right where it belonged. YMMV
awning
Flat panel LEDs: adapter for BA15s sockets rabbit Electrical | Charging, Systems, Solar and Generators 6 04-13-2013 10:33 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 10:54 PM
adding Awning rail and awning to Surfside ericmarlo Problem Solving | Owners Helping Owners 5 06-15-2008 11:01 PM
LED lights in Original light sockets Gerry Modifications, Alterations and Updates 21 01-05-2007 01:03 PM
Adding 12v Sockets & Lights peterh Problem Solving | Owners Helping Owners 17 12-13-2006 03:24 PM
