Awnings and railing. - Fiberglass RV
Old 01-21-2018, 11:24 AM   #1
mensie's Avatar
Anyone installed an awning railing? Our boler didn't come with one but I would like to install one to keep it all vintage. What is involved by installing the railing and what to look for?
Also where is a good place to buy an vintage looking awning? Any places to avoid?
mensie is offline   Reply With Quote
Old 01-21-2018, 11:55 AM   #2
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
Try checking with some of your local RV wreckers. We have a couple of them here in the Lower Mainland and I have seen them advertising awnings on Craigslist. This will at least give you an idea of what could be available for awnings.
There are quite a few members on here from Alberta and I'm sure someone will be good enough to show you theirs and how it is attached.
Old 01-21-2018, 12:20 PM   #3
RV Doctor's Avatar
Mensie.
I am in the RV Service business in Calgary and use my good friend Tony who owns Airdrie Canvas.
They can get almost any SunBrella fabric and produce an authentic and original fabric.
As for the Boler, with its rounded body, you would need to install a mill finish (Aluminum Silver) awning rail.
A lot of Boler owners get very touchy about drilling holes in the body for anything!
If you donít mind having holes, placing the awning rail in place and drilling 1/8Ē holes. Then seal the rail and rivet to the body with Aluminum or Stainless rivets.
Lastly, run a bead of sealant over the top body to rail line to ensure no moisture ever gets under the rail.
Good LUCK!
2017 Bigfoot 25B25FB
2017 F-150 2.7 EB
Full Time RV Living
RV Doctor is offline   Reply With Quote
Old 01-21-2018, 01:29 PM   #4
rad
I went to a vintage trailer show, inquired as to where they acquired there awnings. Marti's Awnings was their answer. martisawnings.com
My Catalina 2500 awning was trashed on my newly purchased older Casita was looking into options for an awning.
rad is offline   Reply With Quote
Old 01-21-2018, 02:15 PM   #5
What's all wrong with your awning Rad? We have one on our Casita that has some issues but have been able to work around them.
Old 01-21-2018, 05:47 PM   #6
rad
When I purchased the trailer Initially thought it was just the plastic end caps searched and searched everyone said parts had been discontinued then I found a place that was able to get the item, they said part# had changed so it was hard to locate, happily began the repair only to find the torsion assembly damaged. Lots of bent parts looks like a frustrated operator had forced things. Probably could be repaired, but this retired guy has way to many projects, and just want to take my Casita adventuring. Took the railing off to clean it as it was a silicone glob. Maybe I'll find a place to mount it near my shop and attempt a repair.
Old 01-21-2018, 06:15 PM   #7
Another retired guy here, also with too many projects. When we bought our Casita SD17 from friends, the guy said it took him two hours to get the awning back in and suggested we may not want to use it. After a few times we found how to operate it without any trouble. DUH, follow the directions. But by this time the end caps had been broken where the legs hook in. For a quick fix I drilled a couple holes in the case at the ends and use wire ties to hold the legs in place. If I can't find replacement end caps I have a plan to make a retainer piece of aluminum angle. On another note, to put an awning on our 13 foot Uhaul camper I bought a length of aluminum awning rail, riveted it on, and bought a Shademaker bag awning which we are reasonably satisfied with.
Old 01-21-2018, 08:07 PM   #8
rad
Maybe sometimes the less mechanically inclined will give up and use the irrational hammer approach, (I have heard they're difficult, but some have no problems), you may have convinced me to look into repairing it.
Old 01-21-2018, 08:22 PM   #9
John in Santa Cruz's Avatar
CA
my Casita has Fiamma awning, annd I recently got endcaps from Fiamma USA, which while they had a horrible tragedy a year or so ago ARE still in business (owner and several other employees including the webmaster were shot by a disgruntled ex-employee).
now, for that vintage Boler, a Fiamma is probably too modern.
and I have to say, the Carefree awning on my new-to-me Escape is a much nicer, sturdier awning, but its like 14x8 feet vs 10x6'.
Old 01-21-2018, 08:43 PM   #10
Where did you get the end caps Randal? Are other parts available?
Old 01-22-2018, 12:12 PM   #11
rad
In the process of trying to figure it out, should I need to order more parts, seem to misplaced the paperwork, will let you know when I figure it out. Seems I read somewhere Fiamma has some parts, have not verified that.
Old 01-22-2018, 03:04 PM   #12
CA
if you have a Fiamma awning, FiammaUSA has all the parts, but due to some chaos there, its typically easier to order from one of their resellers. I used eurocampers.com ...
Old 01-22-2018, 03:20 PM   #13
Randal has a Catalina 2500, same as ours.
Old 01-22-2018, 04:32 PM   #14
CA
ah. well, here's a Dometic Catalina 2500 parts list...
https://www.scamptrailers.com/images..._PartsList.pdf
and these guys seem to ahve the parts.
https://www.anyrvparts.com/a-e-domet...parts-10018977
awning, boler
Catalina 2500 awning railing and fabric $175 Tucson KristiS Parts: Buy | Sell | Trade 19 01-23-2018 02:50 PM
Railing for awning on 77' Scamp Danielle Ash Problem Solving | Owners Helping Owners 3 05-13-2010 12:01 PM
Velcro and awnings. Rozanne G Problem Solving | Owners Helping Owners 16 06-23-2008 12:35 PM
Bunk Railing Amy M. Problem Solving | Owners Helping Owners 7 05-01-2006 05:55 PM
Velcro and awnings. Rozanne G Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
