Back to the jack - does this look good? - Fiberglass RV
Old 07-14-2013, 05:33 PM   #1
Trailer: Chez Nous - a 2011 Scamp 16'
I may need to call Scamp to get a definitive answer, but I thought I'd ask you folks first. Here's the jack I'm looking at ... Side-wind is the key for me.
Here's the specs:
Curt Trailer MFG. A-Frame Side-wind Jack
Has a heavy-duty, swiveling wheel, bolt-on hardware for easy installation, and a heavy-duty pull pin.
Capacity (lbs.): 2,000; Bracket Height: 9"; Travel: 14-1/2"; Wind: Side; Dimensions: 30 x 8-1/2" x 4-3/4"; Weight: 10.9 lbs.
So what do you all think? It's under $30. The used one is under $25.
Sharon
SharonM is offline   Reply With Quote
Old 07-14-2013, 05:43 PM   #2
Just make sure that the distance the non moveable tube extends below the mounting bracket is correct, they refer to it as bracket height.
mary and bob is online now   Reply With Quote
Old 07-14-2013, 05:47 PM   #3
Trailer: 2008 13' Scamp
The brand Scamp used on mine was Atwood. Maybe you could look up the specs for Atwood and see how close they are.
I can't see any reason why that one wouldn't work. It has strong similarities to the Atwood. The triangle mount has mounting holes. Worse case, slight modification required. I did that to mine anyway so I could rotate it 60* so the handle wouldn't hit the tongue box.
Old 07-14-2013, 05:58 PM   #4
Heh!!! One of the single most aggravating things about the jack on my Scamp 16, bought used, is that 3/4 of the label on the jack is torn off. It would probably tell me what I need to know.
Bob, I'll go measure my jack now. This new one says 9".
Well, no dice on height. The below mounting triangle height is 7 1/2 inches, the above mounting triangle is 9 1/2. Geez. what a PITA finding what I need is gonna be.
S.
Old 07-14-2013, 06:00 PM   #5
Brian B-P's Avatar
That makes sense, but Atwood makes these things in lots of sizes, so that won't help confirm that the proposed Curt unit will be the same length.
I agree: measure the existing jack's bracket height - as well as the travel (how far it can extend to reach the ground - and compare it to the Curt dimensions.
The Curt describes - but doesn't show - a wheel. These jacks can also have a plain foot, which is much shorter.
Old 07-14-2013, 06:01 PM   #6
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by SharonM View Post
........ Geez. what a PITA finding what I need is gonna be.
S.
Have you checked eTrailer?
Old 07-14-2013, 06:03 PM   #7
Brian B-P's Avatar
eTrailer, Eastern Marine, Harbor Freight... all the places that people who build their own trailer go, and normal people don't know exist!
Old 07-14-2013, 06:11 PM   #8
Atwood Trailer Jack - 273400
Capacity: 2000 lbs.
Lift: 14"
Clearance: 16" from mounting bracket to top of jack
7-3/4" bracket height
9" retracted height
23" extended height
2-1/4" outer tube diameter
2" inside diameter
This from etrailer. The bracket height seems about right, but I don't know about the rest. This is like buying shoes where 3 brands of 6-B all seem to fit differently.
S.
Old 07-14-2013, 06:27 PM   #9
Don't want to muddy the waters but I did check the retracted length of my Atwood, without the wheel and it was more like 6"
Old 07-14-2013, 06:50 PM   #10
I would say the retracted length is important for road clearance when traveling. I mentioned it because I had a problem with that one time, put jack on trailer then realized it stuck down too far. Detachable wheel would be best too, and they are not all the same as I found when trying to get a wheel for a jack I already had. There should be no problem if they are bought together. Another problem I've had with daughters pop up is when hitched to car he jack won't retract enough to get the wheel on. I have to uncouple, jack tongue up high, put a stand under tongue, retract jack, put wheel on, extend jack to remove stand, swing trailer into position. Repeat all that when leaving site. She goes to a campground where sites are paved and your not allowed to get wheels on the grass and she wants trailer sideways in the site.
Old 07-15-2013, 01:00 AM   #11
gage's Avatar
Trailer: 13' Burro
Now this is funny.
gage is offline   Reply With Quote
Old 07-15-2013, 08:38 AM   #12
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
As Sharon reminds, sourcing replacement parts and hardware for our trailers presents some challenges. eTrailer is a reputable mail order retailer with an online catalog containing adequate description, specification, and photo illustration of all inventory as well as how-to video practicums.
The Eastern Marine Superstore in my area (mid-atlantic) is a brick and mortar warehouse of parts and running gear for travel, utility, camping and boat trailers as well as of recreational boating accessories and fresh and saltwater fishing gear and electronics. Again with a catalog in which specification of service, size, and all other distinguishing particulars are given adequate attention. And the on view inventory puts that of most Camping World locations in the shade.
Harbor Freight is Brookstone in a bad location, the inventory is unspecialized and limited only to what can be produced and sold for flea market change, from novelty wind chimes to monkey on a stick to some seriously heavy and seriously inadequate stationary machine tools and light industrial equipment. The four foot shelf of cargo nets, tie downs, stingers and couplers as well as the tinpot folding trailers and steel wheels do not qualify HF as a trailer supply house. Walmart stores in my area are nearly as good as HF for in store inventory. HF's catalogs and internet descriptions are barebones inadequate. Those who sleep with a greasy Grainger catalog as a pillow may find some light duty equipment and supplies for a price that doesn't pinch.
We spend a great deal of our time here advising the normal and neophytic on parts sourcing. I prefer not to encourage or allow the impression that these three retailers are all serious trailer supply operations, or conversely that none are.
jack
Old 07-15-2013, 09:17 AM   #13
Thomas G.'s Avatar
Originally Posted by rabbit View Post
......from novelty wind chimes to monkey on a stick .........jack
I really like Harbor Freight and try to keep on top of what they sell. I haven't seen the monkey on a stick, yet. I'll look next time I'm there.
Old 07-15-2013, 10:01 AM   #14
rabbit's Avatar
Delaware
To give HF credit where credit is almost due, devoting an aisle to recognizably distinct mechanic trades (plumbing, electrical, auto-body repair) would make it a worthy competitor for some very expensive hardwares such as Ace/TruValue except that HF is all generic supplies, tools and fasteners and NO manufacturer-specific replacement parts. I much prefer Lowes, Home Depot or Ace for one stop shopping. I have some automotive tool sets from HF which have proved adequate for occasional use and some items which were unboxed and culled for completeness and functionality before purchase.
jack
Good price on Electric Tongue Jack Ian G. Towing, Hitching, Axles and Running Gear 0 03-12-2013 07:24 AM
Emergency Jack Kip in Ga. Towing, Hitching, Axles and Running Gear 21 01-31-2011 12:08 PM
Sadie is Back on Santa's Good List Cyndi B. General Chat 11 12-20-2010 06:54 PM
Go back young man go back Edward Shook General Chat 15 01-31-2010 09:30 AM
