10-25-2015, 07:57 AM
Trailer: 2015 Escape 5.0TA
Back-Up/Rear View Wireless Camera Reliability
Does anyone have any comparisons of Tadi Bros. vs. Voyager wireless cameras as to their ability to not have drop outs. I am wondering if the higher price of the Voyager is worth it in terms of reliable performance.
10-25-2015, 08:07 AM
Trailer: 2017 Scamp 16 Deluxe
I also wonder about a backup camera from Yada.
I recently saw one of those at Costco for $99.
Ray
10-25-2015, 12:49 PM
Is this an add-on for the back of the trailer? That could be quite useful.
We have a camera on the back of our tow vehicle. It took a few episodes of beeping before we realized it was seeing the trailer when we turned a little too sharply.
10-25-2015, 02:56 PM
Yes.
What a long strange trip it’s been!
02-11-2017, 09:32 PM
Trailer: 1978 UNIK
Tadi vs Voyager
I'm looking for the right unit myself. Digital wireless is going to cost upward of $250 to $900.
Tadi Bros. has a camera that seems to go on top of your RV because the wireless antenna sticks out the back of the camera and there is no clearance if mounted on a vertical surface like on middle of the back of your RV. The monitor is 7' diagonally and I think I would like a 4.3" or 5" monitor and not clog up the forward windshield view.
The voyager is expensive but they do have a refurbished unit for about $100 less. Part no. WV05511-RM. they have many models to choose from. Higher priced ones have multiple cam inputs, audio, split video, etc.
I would like to know anyone who has a wireless digital cam and the price to let us know. I just can't decide what I have to get.
David & Terry Sergison
02-11-2017, 10:14 PM
Trailer: Escape 21 - Felicity
No experience with Voyager, but I do have the Tadi Bros setup on my Escape 21. I ran the cables from the camera up to the front of the trailer and installed the wireless transmitter at the front of the trailer. The receiver in the truck is mounted to the rear window with 3M VHB tape and the cable routed from there up to the drivers side visor, where it plugs into a "clip on" mirror display.
https://www.tadibrothers.com/product...mirror-monitor
Absolutely no problems in 3 years. Tadi uses the same camera with all of their monitors. Quite rugged and the sun visor for it works great. They use a wireless frequency far enough from the BlueTooth frequency that there is no interference like the cheapies.
02-12-2017, 07:25 AM
Trailer: Casita Independence "Callimachusita"
Ocean City, NJ
I got a 4UCAM that mounts on top of the license plate. It uses a wireless signal to a IPhone or android. I put the transmitter in my tail light. Works great. About $100 on Jet or Amazon.
Gordon and Anne
2010 Suzuki Equator "Suzi Q"
2015 Casita Independence "Callimachusita"
Pod Puppies: Josie and Frankie, Casita Kittens: Madison & Razzel & Mrs. Chow
02-12-2017, 10:02 AM
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
Carl,
I've no experience with these but have had excellent results from an $85 wireless unit by Peak. Camera mounted at the rear of our Scamp and monitor on the TV dash.
Whatever brand, they definitely provide useful information for safe operation. Good luck in your search.
David
02-12-2017, 02:11 PM
Trailer: Bigfoot 30th Anv. 25B25FB
Had a Garmin RV 760LMT GPS unit and and a compatible Garmin BC20-Wireless Backup Camera that worked with the GPS on my previous Bigfoot motor home.. Great camera and easy to install on license plate holder. Motor home was 29' long and no problem whatsoever wireless wise.
Now have a Bigfoot 25' trailer and plan on getting the newer 770 RV GPS unit an camera as well. Nice to see what's behind you when backing up on going down the road. The only thing was during daylight hours you have to put on you parking lights to activate camera. At night not a problem as camera is on, unless you touch screen to go to GPS mode.
Great system........see photos.
03-04-2017, 02:34 PM
Trailer: Parkliner SOLD November 2017
South Carolina
When you switch the to the backup/rear view mode, does the GPS still keep track of your route? I would like to see what the traffic is like behind me every once in a while. A backup on the trailer would be great to see what is behind you when you are backing in to a campsite as well!
03-04-2017, 03:00 PM
Yes it keeps track of where you are at. During the daylight hours, you simply pull on your parking lights or driving lights for that matter and the rear camera view comes on. Watch what is behind you and when done push light switch in and GPS comes back on where you currently are.
I used it that way all the time. At night it will be on because your lights are on, but you just need to touch the screen to switch to the GPS mode. I think it's a really nice setup and easy to install and use.
03-04-2017, 05:46 PM
Trailer: ParkLiner
Virginia
If you wire so it is on all the time, it doesn't work that way. If you are in map, you have to get out before you can get to camera view.
I finally disconnected mine because it started switching between camera and map at every bump.
I thought it would be helpful to see what was behind me while driving, but the resolution isn't good enough. You can't see cars until they are right up on you.
03-04-2017, 06:22 PM
That's basically what I said. You go from one to the other. Never had any twitching whatsoever.
03-11-2017, 05:52 PM
Trailer: Escape
I had a little trouble with my Garmin & BC-20 camera losing communication sometimes when I had the transmitter just inside the front wall of my Scamp. After I remounted the transmitter by cutting out a small square of the foil/bubblewrap insulation so there is just fiberglass it works just fine.
05-06-2017, 09:08 AM
Trailer: 94 Scamp 13 ft
Gordon -- Any photos of the install? Did you get the mini camera or the license plate frame camera?
