Backup lights on trailer - Page 2 - Fiberglass RV
Old 01-27-2015, 06:15 PM   #15
Originally Posted by Jim Bennett View Post
Doesn't seem to be working.
Thanks for 'splaining things.
Well it's working a little bit because I had to think some on what we used the center wire for. Then some trailers were wired so the interior lights on the dry van trailers would only work with the parking brakes on. That created more wiring and a air sensor which translates to more problems. But back to the original topic: yesterday a lady came into the campground with a Casita 17. Lot of trees to watch out for so I was just watching her back in (which she got it in place in one try, no pull ups) and noticed her trailer has built in back up lights and they worked. Now we just bought in November a '96 LD 17 Casita and a 2012 Ram pickup to tow it south for the winter. Got both just a week or so before we left home so no time to do anything except grease the wheel bearings, check brakes, install a high mount stop / turn / marker light, and away we went. Never noticed our Casita also has backup lights. Don't know if they work and won't know for another month. Can't get the truck to the trailer because we have a screen room in front of the trailer.
Old 01-27-2015, 06:42 PM   #16
T I have never seen other than the blue used for brakes. <cut>
Even if the did use the center pin for brakes, that would leave open the one normally used for use with backup lights. A quick test with a meter will tell the tale.
Jim mine does use the blue for the brakes. Except its located on the center pin. If you scroll down on the e-trailer link you will see near the bottom the diagram that is set up as mine is. Its called the "Heavy Duty Truck 7 way Trailer Color Code". Would do the cut and clip as you have done for yours if I had a clue as to how to do that!
Old 01-27-2015, 07:17 PM   #17
Ok so I figured it out! LOL This is how my truck is wired up - although its not a round pin its a seven blade and its a perfect match to how Scamp also did their 7 pin connection for years (as per their manual) & how my connection is wired up though its a blade type on my trailer - although I understand that in VERY recent years (last 4 or less) Scamp changed it to be more as you have noted the Standard 7 pin to be.
Old 01-27-2015, 08:03 PM   #18
So Scamp used two tail / marker light circuits and separate brake light circuit? That's good to know if I ever have to work on one. Any idea which circuit powers what lights? At rallies I seem to be the one that gets asked how to fix things and the one with tools.
Old 01-27-2015, 08:21 PM   #19
Here you go M&B. This is the way my 2010 Scamp is wired and as Floyd said, with "Factory" backup lights. I use a rear camera in my Scamp and at night if backing in, the lights REALLY helps the camera!
I made this drawing awhile back because I wanted to test the rear trailer lights. Now I can by "jumpering" between the "Black" or "HOT" and any of the other tail light, brake lights, etc. blades. It works but you have to be VERY careful and not short anything. Hope this drawing helps....
https://www.flickr.com/photos/50351683@N08/9728844401/
Darral T. is online now   Reply With Quote
Old 01-27-2015, 08:41 PM   #20
Thanks Darral, same as my Casita. So in Carol's photo the brakes must use the center pin? All the other pins are lights and a ground. That's the plug commonly used with an air brake trailer which would have two circuits for tail & marker lights, left and right turn in the outer tail lights and stop in the inner lights.
Old 01-27-2015, 09:22 PM   #21
Bob, as Darral has shown Scamp changed their wiring harness set up about 4 years or so back to how he has shown in his photo link.
Attached is a PDF of the page from the Scamp manual for my 92 and its the same as the manual they use to have for downloading off there website up until they made the change. The PDF shows how they use to do the 6 and 7 pin harnesses wires.
Old 01-27-2015, 11:02 PM   #22
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I have had work trucks wired with this connector, for use with commercial trailers. I have never seen one used on an RV before. So, Scamp never used to use the RV standard 7-pin flat plug until 4 years ago? I know every RV trailer I have had for the last 25 years has.
Did your truck come stock from the factory with this connector? I have never seen this before, it was always added afterwards. I actually have a pigtail I made up to go from the 7-pin round, to the 7-pin flat, from when I used to do commercial construction, so i could tow my trailer with my work truck. Haven't needed it for 20 years now though.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Most folks are about as happy as they make up their minds to be. Abraham Lincoln
Old 01-28-2015, 05:51 AM   #23
Interesting info. Carol thanks for link, but it's not the same as the previous photo you posted which shows a heavy truck / tractor trailer plug that has two pins for tail and marker lights. I was curious about how Scamp did their wiring because my Uhaul did indeed have two separate marker light circuits. But of course Uhaul did not have any standard plug on their campers. Lights were hooked up to the tow vehicle using a connector similar to the Scotch Lock's or the Tap-a-Light bulbs. I'll make a note of the wiring change in case I ever have to work on one of the older Scamps.
Old 01-28-2015, 09:17 AM   #24
Bob, your correct it is a bit different. Scamp used only one line for the marker lights but they also used for years an all in one tailing light that had no back up for years. On the 7 pin - that left the Yellow line unused for adding a future Back Up Light or a Foreign Stop.
Old 01-28-2015, 10:10 AM   #25
Jim I can not say with certainty when Scamp switched their wiring harness set up to the more traditional RV standard you are familiar with. Its simply my guess that it was within the last 5 years for a couple of reasons. A few people have recently mentioned here that Scamp no longer uses the centre pin for the blue brake line - as I recall those who have mentioned it appear to have 2010 or newer trailers. Secondly the PDF wiring harness diagram I posted is the same as the one in the original 1992 manual that came with my Scamp as well as the online manual they had on their web site up until a few years ago. Scamp switched a few years ago to the new video interactive manual on line and the wiring diagram is now different. Floyd is great at knowing all things Scamp, so he probable knows better than I when the wiring change was actually made.
As far as my trucks set up goes - it did come from the factory with the full tow package and wiring per the detailed option sheet included with it and all the parts & install are factory - nice and neat. BUT the truck was 2 years old when I got it so it is possible the previous owner had the wiring switched around for his own set up although I would be surprised if he changed it as all he pulled was a small boat and used a 4 pin adapter for that, which they included with the truck. So what if anything was actually changed on the truck side after it left the factory I can not say with certainty. Just happy it was all neat and tidy and plug and play with my Scamp, including the brake controller.
I do know though that when I took the Subaru in to have the seven pin harness added to the factory 4 pin and a brake & charge lines run for the Scamp I showed the installer the Scamps wiring harness diagram and the party doing the set up took one quick glance at it and said ok and handed it back to me - never looked at it again while doing the wiring. When I got the car home and plugged in the trailer, it all worked as it should. So I am assuming it was something the installer had seen many times before.
Old 01-28-2015, 10:22 AM   #26
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
This discussion has me re-thinking the potential of "back-up" lights. I like Floyd's idea of some bright down/side lighting for backing into a site in the dark. I'm not an expert on electrical, but wouldn't an inexpensive remote operated from in the TV avoid much of the wiring hassle? You could just wire the driving lamps to the panel in the trailer via a remotely controlled relay. Quick search on Amazon located this as an example: "Logisys RM02 12V 15AMP Relay Kit with Two Remote Controls" Would this work?
WDavidG is offline   Reply With Quote
Old 01-28-2015, 06:28 PM   #27
Radar1's Avatar
Name: Dave (and/or John)
My 2005 Scamp has the center pin used for the standard backup lights, same as the diagram Darral posted. So, they've used that configuration at least that long.
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
light, lights
Backup lights Borden Towing, Hitching, Axles and Running Gear 4 11-18-2014 08:11 AM
Adding backup lights to TT knighth001 Problem Solving | Owners Helping Owners 9 03-06-2013 05:01 AM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 09:10 AM
Bigfoot trailer backup lights not working Carol Crawley Problem Solving | Owners Helping Owners 5 04-26-2008 10:37 PM
Backup Power? Art Davis General Chat 3 03-23-2007 08:04 PM
