bad ground in Boler? - Page 2 - Fiberglass RV
Old 07-08-2003, 03:44 PM   #15
buss bars are pretty common
Home depot has them even look where they have Circut breakers and boxes . it look like a bar 3 to 6 inches long lots of hole s in the sides for wire and screw to tighten them in the bar is about a 1/4 inch square or rectangular in shape . bars are sold in napa westmarine . the wire wire in your wire harness to the car should be the ground bond (run wire to and connect) to the buss bar then run to wire harness. try not to depend on the metal frame of your trailer for a ground. for reasons to long and complex to be explained here not to be snooty of any thing but it has to do with dissimilar metals and corrosion creating weak points in the frame and inconsistant ground.:cheers
Old 07-08-2003, 06:00 PM   #16
busbar
Thanks.
I'll go that route and get a good ground via a busbar via the cable to the truck.
Old 07-08-2003, 10:53 PM   #17
Orginally posted by rproudman
* * * * * * Thanks.
Howdy, I`m assuming that you have a battery in your trailer and there must be a ground wire from the battery terminating somewhere and that would be a take off point or a mounting point for your central ground which should also be already connected to the ground from your tow vehicle...Benny
Old 07-09-2003, 06:02 AM   #18
Benny K
the ground to tow vehicle is the problem . I agree taping into the battery ground is a good idea if there is an installed battey. That way you have a good ground for chargeing battery on the road.
boler
Where is the ground hiding? Kevin A Problem Solving | Owners Helping Owners 11 04-30-2008 10:20 AM
ground question Randy Dewey Problem Solving | Owners Helping Owners 6 07-30-2007 11:46 AM
Camp Ground Books D Tharp Care and Feeding of Molded Fiberglass Trailers 32 02-14-2007 08:23 AM
Prodigy.. electrical battery ground ? Christi V. Problem Solving | Owners Helping Owners 16 04-20-2006 10:19 PM
Ground Clearance for Eggs Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 10-30-2002 10:16 PM
» Trailer Showcase
Ova
xichael
1983 Burro
Bluepea
