bad rims 2016 Scamp ? - Fiberglass RV
Old 03-19-2016, 04:06 AM   #1
Trailer: 2016 13Ft Scamp
bad rims
13 ft Scamp 2016; tapper to lug hole
From Backus to Florida I check the lug nuts every stop for the first 3000 miles everyone was OK
About 13000 miles///// for some reason checked them again ////.four lug nuts was loose about 1/4 turn ...the other rim two was loose.
What I found was little to no tapper to the holes and the lug nuts are being cut because of no or little tapper to the rim holes
Does my new scamp have three bad rims?
EugeneFlorida is offline   Reply With Quote
Old 03-19-2016, 04:58 AM   #2
Borrego Dave's Avatar
Kind of sounds like it, give Scamp a call, they may have received a bad batch.
Old 03-19-2016, 08:12 AM   #3
pictures please
Old 03-19-2016, 08:34 AM   #4
Do you check them with a lug wrench, preferably a torque wrench, or just visually. Being just a little loose could cause the wear into the nuts. And then the looseness increases
Old 03-19-2016, 10:08 AM   #5
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
Could the rims be installed inside out ? I saw it once on a car from the factory.
Bob in Mb is offline   Reply With Quote
Old 03-19-2016, 10:33 AM   #6
Trailer: 2016 -13' Scamp
Massachusetts
The sound of that issue makes me nervous about picking up a new Scamp soon.
herons is offline   Reply With Quote
Old 03-19-2016, 10:47 AM   #7
A good reason to spend some time touring Minnesota before heading home and to check lug nuts frequently during the break-in period (as recommended by Scamp).
In this case I would take it to a local tire and wheel shop and get their assessment of the situation. A professional diagnosis will help you work with Scamp if there is a defect.
Let's not rush to judgment...
Old 03-19-2016, 10:50 AM   #8
BillE's Avatar
Trailer: Scamp 16 ft
Calm down everyone..
We picked up our 13 ft Deluxe on Jan. 2nd , 2016 in Backus MN. I checked the torque at the factory along w/tire pressure...then at a few stops along the way.
Backus MN = 110ft/lbs
Little Falls MN = 110ft/lbs
Ramsey MN = 110ft/lbs (about 150 miles)
Oshskosh WI = 110-112ft/lbs (450 miles)
Glenbeulah WI = 111 ft/lbs (485 miles)
..Then I took the wheels off and put on some aluminum rims....only because I liked them. Wheels, lug nuts, and center cap $70 shipped to my door.
A three egg family..
(2) Big Green Eggs for cooking..(1) Egg for camping
BillE is offline   Reply With Quote
Old 03-19-2016, 10:51 AM   #9
Don't sweat it! this is a very isolated case with no determination of cause.
If you like, you can have your wheels re-torqued before you leave the factory.
Old 03-19-2016, 11:00 AM   #10
here some pics
Old 03-19-2016, 10:23 PM   #11
Trailer: 1978 Burro
lug nut and wheels
Originally Posted by EugeneFlorida View Post
here some pics
Wow, Eugene! You do need to contact Scamp. I'm no expert but it appears that the lug nuts don't match the rim. It looks like the rim has cut a groove right into the lug nuts?
Here is something I found on the internet. Spherical seat and conical seat lug nuts.
A Few Facts About Lug Nuts - Performance Plus Wheel and Tire
DuaneQ is offline   Reply With Quote
Old 03-20-2016, 05:01 AM   #12
Thanks
Funny you should say that... the video on tires and rims said the lug nuts take a 3/4 socket but mine have 13/16 socket really glad I stopped and bought a set of 1/2 drive socket, on the way back to Florida.
Has anyone else had the rim holes and Lug nuts look like mine
Old 03-20-2016, 07:24 AM   #13
cpaharley2008's Avatar
Actually the nuts look normal, the rims are tapered but the nuts shouldn't be cutting the metal unless they are being over tightened. I'd suggest using a torque wrench with the proper setting versus a socket wrench which can and do strip the wheel rims. Also why are the nuts so clean and the rims so dirty and greasy?
Jim
Never in doubt, often wrong
Old 03-20-2016, 09:36 AM   #14
Pictures are about as clear as possible.
No obvious indications of any flaw that I can see.
One possibility would be a heavy coat of paint which prevented the lug nuts from taking an initial set.
I'd say simply remove and retorque each lug nut, making sure all excess paint is gone from the tapered seat and the wheel is snug against the brake drum.
torque specs vary from chart to chart (I use 90psi for 1/2" studs)
This will probably solve the problem... Then trust but verify after a few miles.
I assume that what may look like grease is actually only the bare metal where the lug nuts have been tightened.
Is there any indication of thread damage?
VERY UNLIKELY BUT...
Check to be sure that the studs and the lugs are compatible. That is to say both SAE threads or both Metric. (Threads not wrench size)
Old 03-20-2016, 11:35 AM   #15
Trailer: 1978 Burro
lug nut torque
Thanks
Eugene, I think that the lug nuts were just under torqued. The groove may have been cut into the lug nuts because the wheel was loose and wobbling.
I took a bus to Phoenix yesterday and saw that some of the buses had lug nut indicators on them.
Wheel-Check, loose wheel-nut indicator, made in North America
As someone has said earlier a torque wrench is almost a must if a person doesn't have a real good feel for torquing bolts and nuts. Clean threads are important also when torquing. I have been using a tough of anti-seize for years on my lug nuts but don't recommend it for others.
Changing rims on 13' scamp DavidS Towing, Hitching, Axles and Running Gear 3 08-08-2009 06:55 PM
Scamp rims: 4 lug Dan R General Chat 5 09-29-2008 01:05 PM
Bad bad news Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
