Prior to putting on the paste I tried a dry run if you will. Bearing in mind that plastic threads are delicate creatures, the clamp made hand turning the fitting quite difficult. No heat. Next, I put the paste on the fitting, screwed it in and tightened the clamp. I let it cure over night and the tank is currently sitting outside on a bench. It is full of water. So far so good. It won't leak until it is back in the trailer. Murphy, you know. Raz
