Old 04-22-2012, 10:53 AM   #1
P. Raz's Avatar
Vermont
Bad threads on the water tank. Ideas?
The water tank in our Trillium sits in a molded well beneath the rear dinette. The drain pipe exits the drivers side of the well to a valve behind the rear tire. There is a 1/4" tee in this line that feeds the water pump. Very close quarters to say the least. The tank has always drained slow and never drains completely since the bottom of the tank is lower than the drain valve. Also there is always some wetness under the tank. I attributed this to sweating
P. Raz is online now   Reply With Quote
Old 04-22-2012, 10:55 AM   #2
P. Raz's Avatar
Vermont
The tank hole is 1/2" mpt, so I took the whole thing apart and replumbed with 1/2" tubing and raised the tank up so it will better drain. Unfortunately the threads on the hole are worn, apparently from the tank moving around, and will no longer seal tight. The wetness I thought was sweating must have been a slow leak.
There is no access to the inside of the tank and that hole is the only one that can be used. I am thinking of epoxying the fitting into the hole but thought I would see if any one has a better idea. Raz
Old 04-22-2012, 11:00 AM   #3
Have you considered adding a deck plate to the top of the water tank? That would allow you to not only get all the water out, but thoroughly clean the inside as well.
Inspection plate installed in water tank
Deck Plate
Double Yolk
1988 16' Scamp Deluxe
Old 04-22-2012, 11:17 AM   #4
Thomas G.'s Avatar
Trailer: UHaul CT13 TV: Escape Hybrid
SE Michigan
Deck Plate
It would also allow you to use a fitting with a nut on it on the inside to get a clamping seal as opposed to a thread seal.
I like your idea of raising the tank with foam insulation - I have the same issue.
Just call me Tom.
Thomas G. is online now   Reply With Quote
Old 04-22-2012, 11:21 AM   #5
P. Raz's Avatar
Vermont
The deck plate is the solution of last resort. Thanks
Old 04-22-2012, 11:30 AM   #6
Thomas G.'s Avatar
SE Michigan
I'd be tempted to use lots of Teflon pipe tape and put a pig tail in the line so the hose flexes instead of stressing the fitting in the tank when movement occurs.
Just call me Tom.
Old 04-22-2012, 12:12 PM   #7
P. Raz's Avatar
Vermont
I tried extra Teflon tape. The threads are too weak. The tank movement coupled with the stiff PEX tubing has really done a job on the threads. Right now I am thinking JB weld to make the fitting and the tank one and replace the PEX tubing with vinyl. Keep the ideas coming. Raz
Old 04-22-2012, 01:15 PM   #8
Thomas G.'s Avatar
SE Michigan
A two part epoxy like JB Weld might work. Would it help to put a stainless steel hose clamp around the outside of the protrusion of the tank? If you heated it and tightened the clamp at the same time you might be able to get it to get a better grip on the inner fitting.
Just call me Tom.
Old 04-22-2012, 01:29 PM   #9
Plumbers Goop?
Old 04-22-2012, 01:46 PM   #10
Thomas G.'s Avatar
SE Michigan
Originally Posted by Darwin Maring View Post
Plumbers Goop?
Not a bad idea. This stuff is more flexible than epoxy when it has cured.
Just call me Tom.
Old 04-22-2012, 04:17 PM   #11
It appears to me that any tube of the goop will work. I think they are all the same formula and they just package it with different names just to sell the stuff. Shoe goop in the shoe department, plumbers, campers and so forth in the other departments. I always keep a tube around. It takes at least a day to set up and then cures for an even longer time and really holds. Because it's on your water supply I would be careful of toxic chemicals other adhesives may have.
Old 04-22-2012, 04:24 PM   #12
What's the tank made of?
I.E. If it's PVC then you could simply glue in a PVC fitting after drilling out the threads. That fitting could have internal threads into which you could attach the drain line. If ABS then of course....
Old 04-22-2012, 04:29 PM   #13
Mouse's Avatar
Trailer: U Haul CT13
What I did is choose a bigger threaded pipe and force it in the hole and having it cut new threads.
Mouse is offline   Reply With Quote
Old 04-22-2012, 04:36 PM   #14
Trailer: 2007 Eggcamper
Raz,
I would try some GRIP (same as gasket cement used on cars). Than a stainless steel hose clamp as Tom had said. I would NOT try epoxy or pvc cement unless you know what the tank is made of (it might melt the tank if not compatable).
Art
artspe is offline   Reply With Quote
17" Boler Trailer - Waste Water - Black Water Tank waroibns Problem Solving -- Owners Helping Owners 6 05-20-2011 08:19 AM
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
Water supply hose to the holding tank - grey water Kathy L Problem Solving -- Owners Helping Owners 2 08-26-2009 04:52 PM
Water Tank fill valve from City water line! Michael Pupeza Problem Solving -- Owners Helping Owners 6 06-20-2008 04:10 PM
Larger Fresh water Tank Ideas Steve Rosenberg Problem Solving -- Owners Helping Owners 8 12-15-2007 06:36 AM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
