Ball size for 2005 Scamp 13 ? - Fiberglass RV
Old 07-27-2007, 05:14 AM   #1
Trailer: 13 ft Scamp
Just purchased a 2005 scamp 13ft. The owner said it used a 2" ball yet the owners manual says 1 7/8". There is other info in the owners manual which appears outdated and incorrect. (plug wiring). Does anyone know what size the ball would be on a 2005 Scamp 13 " ?
Mikeny is offline   Reply With Quote
Old 07-27-2007, 08:32 AM   #2
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
My 2004 was 1 7/8". I think they went to 2" with the new, improved post-fire 2007 model.
Patrick M. is offline   Reply With Quote
Old 07-27-2007, 08:52 AM   #3
Look on the top of the hitch that is welded to the camper and it should state the size. That is the size of the ball you should install on the tow vehicle.
If U can’t find where it states the size then a 1 7/8” ball will be extremely sloppy in a 2" hitch and a 2" ball will not go inside the 1 7/8' inch hitch.
Here’s the solution:
Go to one of the following, Northern Tool, Tractor Supply, WallyWorld, Advance Auto and purchase one of those multiple ball mounts and U will be ready to pull a trailer with any size ball.
http://www.northerntool.com/webapp/wcs/sto...970_14093_14093
Old 07-27-2007, 12:29 PM   #4
Or buy one of each, return the one you don't use!
Better yet... call Scamp... 1-800-346-4962. They may ask for the VIN number, so be prepared.
Old 07-27-2007, 01:00 PM   #5
Brian B-P's Avatar
Darwin's right: read the coupler, or if the trailer is still with the previous owner have him read it. Many people don't realize the information is there, because it is generally stamped in (not printed on a label).
Since those ball mounts with three permanently mounted balls do not allow adjustment to the correct height (they're zero-rise, for all sizes, only), I would not want one. I vote for Donna's solution: get both, and use the one which is right. Balls are so cheap you could give away the extra one and it wouldn't cost much more than the cost of driving to the store to return it.
Old 07-27-2007, 02:33 PM   #6
Better yet, Get one of these kits and you can bolt it on as required and U are ready for any size hitch.
http://www.masterhitch.com/hitchAcc.asp?prodID=26
Old 07-27-2007, 02:47 PM   #7
Brian B-P's Avatar
I looked at the Convert-A-Ball (and similar designs), and in combination with an adjustable-height ball platform they could make a pretty cool universal tow connection.
On the other hand, the interchangeable balls and adjustable mounts are so much more expensive than fixed-size stuff that it's cheaper for the person with a couple of trailers (like me) to have a ball mount and (normal) ball combination for each trailer, than to have one universal setup. Maybe it's just me, but I don't find it difficult to switch balls in a mount, either - two minutes and one wrench, and the ball size is changed.
Old 07-27-2007, 06:48 PM   #8
Trailer: 13 ft Scamp Deluxe No More .. Sob!
My 13' Scamp Deluxe is a 2005. I bought it new. It has a 1-7/8" ball.
Ron Mayo
RonMayo is offline   Reply With Quote
Wrong size hitch ball Kevin K General Chat 10 06-23-2009 04:09 AM
1976 Trillium 13' - ball size? Sahm J Towing, Hitching, Axles and Running Gear 8 10-21-2008 10:40 AM
Need some help, ball size & towing Arline Lovell Towing, Hitching, Axles and Running Gear 10 06-08-2008 02:59 PM
TRAILER BALL SIZE ??? Dan Quinn Problem Solving | Owners Helping Owners 2 06-07-2006 01:50 PM
