Bargman L400 bolt fix - Fiberglass RV
Old 09-19-2019, 09:32 AM   #1
Trailer: 1978 Trillium 1300
So, after fixing my Trillium's sagging door it became evident that the soft metal used on the bolt for the door handle had worn to the point where the door could be opened with it locked. I read the threads about replacements being unavailable or ridiculously priced (saw a set on ebay with a buy it now of $350US). So I disassembled the lock following the detailed and entertaining instructions provided here.... https://gonedriving.ca/more-boler-ad...tant-survivor/
I had also saw it mentioned that someone had gone to a welder who said the metal was too soft to build it up. So, I took it to a well known trials bike dealer/rider who also happens to be a very talented welder (he repaired the broken frame on my KLX250s). He suggested a different approach, that being, cut the hard steel behind the soft metal and weld a 1/4" spacer. Two hours later (1.5 hrs BS'ing and 20 mins work) it was done all for the cost of $30cdn. I did a little reshaping of the soft metal, reassembled the lockset and was a happy camper when I locked it, pulled and the door stayed closed.
The lesson......when someone says it can't be done, someone else may have ideas to accomplish the same goal.
2morebeer is offline   Reply With Quote
Old 07-13-2020, 07:16 AM   #2
Markz's Avatar
Did the original lock have a rubber gasket behind it?
When reinstalling one would a rubber gasket be better than butyl or maybe a butyl and rubber gasket combo?
I found this rubber material on Amazon and was thinking about using it.
I welcome your thoughts. Click image for larger version
Markz is offline   Reply With Quote
Old 07-13-2020, 11:18 AM   #3
Hi Mark,
There was nothing behind it when I removed it and so I'm pretty sure I didn't put anything back. However, in retrospect, I think some butyl tape or rubber gasket would be a good to use.
Scott
Old 07-13-2020, 11:57 AM   #4
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
I used Butyl Tape when I installed mine.
Alex Adams is offline   Reply With Quote
Latch Bolt restoration (Bargman L400) Alain B. Problem Solving | Owners Helping Owners 13 06-25-2018 07:50 AM
Bargman L400 Repair Kit New In Package EBAY Josh Henderson Classified Archives 7 10-04-2011 06:49 PM
Looking for Bargman L400 Latch LeeAnne Classified Archives 3 11-09-2010 07:14 AM
WANTED any parts, any broken Bargman L-400 L400 Arthur Santiago Classified Archives 4 07-14-2008 12:49 AM
