Bargman L400 Striker Plate Dimensions - Fiberglass RV
Old 06-06-2018, 12:58 PM   #1
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Could someone measure the following on the standard striker plate used with a Bargman L400 lock set please?
length
width
opening length
opening width
distance between the screwholes
distance from the left or right side edge to the screw hole
distance from the top or bottom edge to the screw hole (same hole as above)
thickness of the plate
I think I found a place to get the actual Bargman striker Plate but want these measurements just in case.
Old 06-07-2018, 09:18 AM   #2
Trailer: 1984 UHaul CT13
Alex, I'll go measure mine. will get back to you in a few minutes. Patti
keekers is offline   Reply With Quote
Old 06-07-2018, 09:41 AM   #3
length 4 3/4
width 1 1/2
opening length 3/4
opening width 1/2
distance between screw holes 1 1/2
distance between bolts 2 1/2
side opening to bolts 1/2
distance from top edge to screw hole 1 3/4
distance from top edge to bolt 1 inch
thickness of plate, not very maybe 1/16
Hope this helps. Patti
Old 06-07-2018, 09:47 AM   #4
Alex Adams's Avatar
New Hampshire
One more request, if possible. Could you take a picture of what it looks like? The ones I found with an internet search (they all look the same) don't appear to match yours. Here is a link:
MOBILE HOME DOORS & STORM DOORS - Door Locks - BARGMAN STRIKE PLATE DISCONTINUE - mobilemart.com
Thanks for your help, it is much appreciated.
Old 06-07-2018, 09:51 AM   #5
Alex, that isn't even close to the one on my UHaul so pic would not do you any good.
Sorry
Old 06-07-2018, 10:00 AM   #6
Alex Adams's Avatar
New Hampshire
OK, thank you for your help. Hopefully someone with a Boler will have the L400 striker plate installed by the factory. Mine has a "home made" one.
Old 06-07-2018, 10:49 AM   #7
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
Go to youtube and type in L400. Ian Giles has a vedeo on hiw to replace the L400 with a new lock. That video has the original striker plate in it.
Old 06-07-2018, 11:43 AM   #8
Alex Adams's Avatar
New Hampshire
Thanks Steve. That answers a lot. Apparently the PO fashioned a replacement using an original as a guide. It just looks a little too "home made" for my taste. I may see if I can find a piece of L aluminum or steel that I can use to replace what is there. Thanks for your help it was really illuminating.
Old 06-07-2018, 01:51 PM   #9
ststefan's Avatar
Maple Ridge, B.C.
Glad I could help. The striker in Ians video is identical to mine. Unfortunately I'm at work right now and couldn't take a picture for you.
Old 06-07-2018, 02:14 PM   #10
Alex Adams's Avatar
New Hampshire
Thank you Steve for the offer, but it isn't necessary.
Boler Striker Plate WISE LABS Problem Solving | Owners Helping Owners 4 02-01-2016 01:13 PM
NEW Scamp lock/handle and striker plate highlandsgirl Classified Archives 1 12-01-2010 09:29 AM
scamp door lock/handle/striker plate highlandsgirl Classified Archives 0 08-07-2010 10:26 PM
» Trailer Showcase
Cadet
dgb
Pete
Chooch
