Bargman lock on Ventura ( I believe a L400) questions - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 07-23-2016, 09:48 PM   #1
Trailer: Ventura
Manitoba
1.its silconed on outside but water is coming in around the lock so..
2. Anything I need to be careful with when removing ?
3.how was it originay sealed ..buthyl tape??
4.my lock sticks what can I do so it unlocks better ? As well you can't lock or unlock from inside without lots of force( fearbwell break) so i made a redneck inside lock lol but if I can fix when its off let me know
Cheyanna83 is offline   Reply With Quote
Old 07-24-2016, 03:54 AM   #2
Raz
Raz's Avatar
As I'm sure you are aware Bargman locks are no longer made and sell for hundreds on eBay. Even the repair kits are pricey. My trailer came with one of the last L300's made. I took it off once to lubricate it. Two scews and it was off. Butyl tape was what they used and what I used. With silicone you'll have to work at it. I'd use a hair dryer and a putty knife. Loosen the screws but don't remove them to avoid having either side fall to the ground and break.
We've had members take their locks to a locksmith with some success. Some parts like springs are common items. Some are not. If it just needs cleaning and lubrication they should be able to handle it. Good luck. Raz
Old 07-25-2016, 01:12 PM   #3
Trailer: Ventura
Manitoba
Its off ! Know to clean up silicone and the lock its self
Know on that my door inside has some rot can I kill mold let really dry and fill with foam?? I just can't afford a new door!
Old 07-25-2016, 01:13 PM   #4
Trailer: Ventura
Manitoba
Some pics
Old 07-25-2016, 03:27 PM   #5
Dudley's Avatar
Trailer: 1998 Casita 17 SD
On my latch , the latch had a groove worn into it from the stricker plate on the frame which caused the latch to bind up. I took a file to it to remove the groove. On guy on here fixed his with an aluminum piece.
bargmann repair
BTW Raz if you need a L300, have a used one in the garage!
Old 07-25-2016, 03:41 PM   #6
Raz
Raz's Avatar
Thanks for the offer but mine is in great shape and I found a rebuild kit before they got pricey. Consider putting it on eBay and financing your next vacation.
Old 07-25-2016, 04:20 PM   #7
Dudley's Avatar
Ya the prices are crazy. I was lucky to find a l400 rebuild kit for about $30 , now they are $150.
Old 07-25-2016, 05:54 PM   #8
Trailer: Ventura
Manitoba
Am I missing a part on my lock to make the inside lock work? Hmm works if I press down on ops site end where lever is
Old 07-25-2016, 06:30 PM   #9
Dudley's Avatar
the piece with the black plastic cap looks bent, should be straight up and its the lever you use to lock it from the inside. Everything else looks good
Old 07-25-2016, 07:00 PM   #10
Trailer: Ventura
Manitoba
Other angles I'm trying to figure how it's bent lol
Old 07-25-2016, 09:25 PM   #11
Dudley's Avatar
so is it working now or was it straight to begin with?
Old 07-25-2016, 11:03 PM   #12
Trailer: Ventura
Manitoba
I didn't change anything lol I soaked it in lithium grease seems to be moveing more and more as it works in so here's hopeing
ventura
Bargman L400 lock Dudley Problem Solving | Owners Helping Owners 0 05-22-2012 10:09 AM
Bargman L400 Lock Mal M Problem Solving | Owners Helping Owners 3 07-06-2010 07:10 PM
