Bargman on a Scamp? - Fiberglass RV
Old 10-11-2013, 01:21 PM   #1
Trailer: scamp
Bargman on a Scamp?
Has anybody here ever changed over an old Scamp door lock to a Bargman? I have the Bargman here, and while the door looks a bit thin, it still looks possible.
Has anybody done this? Remarks?
ThomKat is offline   Reply With Quote
Old 10-11-2013, 01:40 PM   #2
IllAnnoy
It's not a bargman but here is an FIC on my Scamp...
Old 10-11-2013, 03:16 PM   #3
honda03842's Avatar
Name: Norm and Ginny
Floyd, Like your lock. What does FIC stand for and where did you purchase it? Any installation tips? Does it work with the catch on the stamp door?
Thank you.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-11-2013, 03:20 PM   #4
honda03842's Avatar
I found the FIC locks. Do you have a specific model? Did you have to increase the door thickness?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-11-2013, 03:28 PM   #5
IllAnnoy
Thank you.
I had to make my own striker....
The door did not have to be thickened.
Several people have done this mod since I did it.One fellow did a nice job and an even better job of documentation. it's around here somewhere (or over at Scampers. If I find it I will post a link on this thread.
Old 10-11-2013, 04:43 PM   #6
Raz
Raz's Avatar
Vermont
Since Bargman no longer makes door locks, the prices have gone sky high. Check eBay to see what I mean. Instead of installing an old lock that could require costly replacement parts some time in the future, you might be better off selling it and buying a new lock with the proceeds. Just a thought. Raz
bargman lock | eBay
Old 10-11-2013, 04:51 PM   #7
David Tilston's Avatar
My thoughts exactly.
Old 10-11-2013, 07:17 PM   #8
Trailer: scamp
Well, Raz-
I have two Bargmans in perfect shape, and I also have a brand new set of lock and latch from Scamp. It's no contest- the Scamp hardware is badly designed and the brand new inside latch is already starting to rust, before it's even installed. I hate the setup. The inside and outside pieces should bolt together and form a solid unit, gripping the door between them- like the Bargman goes together. The Scamp hardware is not a good design.
Does anyone know of a good alternative to the Scamp door set?
Old 10-12-2013, 05:54 AM   #9
Raz
Raz's Avatar
Vermont
Well, Raz-
My Trailer came with a Bargman L 300. Right after the trailer was made Bargman stopped selling locks. Both the L 300 and the L 400 require unique holes which makes replacement an issue, thus the high prices on eBay. I have a rebuild kit and have taken mine apart to lubricate. There are pot metal parts as well as steel parts susceptible to rust. A good seal is a must. I found the need to use loctite on the screws to stop the lock from loosening. Since you have two, replacement parts are not an issue. Cutting the holes in the door and setting the striker might be. My door has a wooden plug inside to give the lock some thing to squeeze. If you go that route make sure your door is thick enough.
I would suggest you search the site before cutting. There are many threads on the Scamp lock. I like Floyd's solution but there are others. Use the google option ( second blank down) of the forum search feature. Good luck, Raz
Scamp door latch alternative...
New Scamp Door latch
Old 10-12-2013, 08:22 AM   #10
Trailer: scamp
Thanks for the insight- I really thing the Bargman is too thick to fit the Scamp door(or the door is too light to anchor that Bargman), but the thought of putting that awful Scamp latch on there gives me fits.
What I was really looking for was a good alternative.
I will check into those FIC units, but I'm still looking...
Old 10-12-2013, 08:53 AM   #11
Raz
Raz's Avatar
Vermont
Please share your solution. I always like seeing what folks come up with. Take care, Raz
Old 10-12-2013, 11:16 AM   #12
Norm I admired a lock at the Bandon meet of an install of a lock much likes Floyd's. In that case they had simply used a thick piece of plexiglass cut the same size as the lock and place it under it to thicken the door. Basically they just put in a thicker spacer than what Scamp currently has. Much like the way Floyd added the a piece of ? but he has nicely hidden the spacer under the rat fur.
Old 10-14-2013, 05:53 PM   #13
Trailer: scamp
I keep holding that Bargman up to the Scamp door- I went so far as to draw the opening I would have to cut out. The only thing stopping me is that size and heft of the Bargman- I really think it's too big to mount in that light Scamp door. If I could find something like it about 2/3rds that size, I would go ahead and install it. I'm still looking at various latches and handles from other older campers...
Has anybody gone ahead and installed the Bargman?
Old 10-14-2013, 06:06 PM   #14
[QUOTE=ThomKat;424943The only thing stopping me is that size and heft of the Bargman- I really think it's too big to mount in that light Scamp door. If I could find something like it about 2/3rds that size, I would go ahead and install it.[/QUOTE]
Whats wrong with one like Floyd posted the photos of?
For Sale: BargMan L-400 paul friedrich Parts: Buy | Sell | Trade 23 10-12-2015 07:59 PM
Replacing Bargman 92 series taillights with Bargman 07 LEDs Fran L Electrical | Charging, Systems, Solar and Generators 8 06-29-2015 12:53 PM
For Sale: Bargman 300 kootenaigirl Parts: Buy | Sell | Trade 2 08-01-2013 12:32 PM
Wanted: Broken Bargman L400 or barrel lock for Bargman l-400 freddo411 Parts: Buy | Sell | Trade 1 05-24-2012 02:18 PM
Bargman L300 Pam Garlow Problem Solving | Owners Helping Owners 2 09-17-2011 07:45 PM
