Bathroom taps - Fiberglass RV
Old 11-06-2017, 06:07 PM   #1
Bathroom taps
I have a 19' 19'88 bigfoot and the taps leek. I pulled out the valves and went to the local plumbing store and they laughed at me!! They say even if I could find such an obscure part I'd be dumb to install a nylon valve in the first place.
First question....does anyone know the manufacturer used by bigfoot for taps in '88?
Second questin...if they can't be found how do you change the tap set? Do I have to drop the tanks and do it from the outside?
Bolerpuller is offline   Reply With Quote
Old 11-06-2017, 07:41 PM   #2
rbryan's Avatar
Arkansas
Can't you just pull and replace the faucet? A decent RV bathroom faucet is inexpensive.
Old 11-06-2017, 08:00 PM   #3
I could, but I can't see how to access it. the whole bathroom is one big insert. Looks like I have to drop the black water tank to get to it?
Old 11-06-2017, 09:19 PM   #4
Mike Magee's Avatar
Trailer: Li'l Hauley
Maybe Bigfoot can advise you if you give them a call or email. Not sure, things have changed around there since '88, but maybe....
I'm just one step away from being
filthy rich. All I need now is money.
Old 11-06-2017, 09:34 PM   #5
Wait... Bigfoot never made the faucet for the bathroom. They're probably 4" centers. Kinda like you'd find in a lot of sticks 'n bricks home bathrooms. I replaced the taps in my 1988 Scamp. I went to Camping World (closest RV parts place to me), with the part I was able to dig out.. it was a cone shaped washer. PEX to faucet. Probably not something you'd find at a local hardware store, but something pretty common at an RV parts store. I hope you can figure it out
Sorta looked like this
Old 11-06-2017, 09:40 PM   #6
rbryan's Avatar
Arkansas
Any chance you can post a photo? It sounds to me like the plumbing was built in such a way that it's accessed elsewhere. Maybe there's a panel on an adjacent wall to the bath? I've seen alot of threads about what a pita it is to replace. Obviously Bigfoot never anticipated it would need to be accessed.
Old 11-07-2017, 08:53 AM   #7
Trailer: Bigfoot 17' DLX
Alaska
I don't know how it is on the 19-footers but when I replumbed my 17-footer I was able to access the lavatory plumbing through the access door on the left-rear to the small storage area there. There is a picture of the plumbing there in this thread.
WIFI
trainjunkie is offline   Reply With Quote
Old 11-07-2017, 09:43 AM   #8
rbryan's Avatar
Arkansas
WIFI
That's kind of what I thought. There usually is another way to access it if it's not visible from the sink area itself.
Old 11-07-2017, 02:49 PM   #9
Hope these help. As you can see there isn't an easy way to get at the taps, I managed to find the bottom by going through the access panel on the bottom left (Thanks trainjunkie) but its so far up I can't reach it. (Special tool?) I also took a pick the valve itself in case anyone recognizes it?
Thanks!
Old 11-07-2017, 04:24 PM   #10
Trailer: 87 Scamp
Southern New Jersey
They lasted since 1988, just buy replacments and replace them.
JOE DRISSEL is offline   Reply With Quote
Old 11-07-2017, 05:28 PM   #11
Ya, that was my first move, but it's easier said than done.
Even having found the access to the bottom of the taps, I can't reach them. My arms are about 4 inches too short. In fact, taking the picture above is the only way I've been able to see them at all.
Old 11-07-2017, 05:54 PM   #12
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Amazon
https://smile.amazon.com/Dura-Faucet...hower+diverter
Old 11-07-2017, 07:11 PM   #13
I'm reading this as the problem is the faucet valves are leaking, not the connections from the piping. So if that is the case, is it that the valves won't completely shut off and the faucet drips, or does water leak up around the valve shaft and out under the handle. If either is what is happening you may be able to find the bottom rubber washer (or modify one to fit) and the correct size o-ring, rather than a replacement valve insert. Sometimes you have to get lucky and find the right place and person to help you, rather than just the answer of "you're nuts to do that" You could probably get the lines disconnected from the faucet assembly using a basin wrench, but I don't know how you would connect them to a new faucet if you can't reach it.
Old 11-07-2017, 07:25 PM   #14
mszabo's Avatar
Buy the new faucet and use the parts from that to repair the old one.
bigfoot
Bathroom or no bathroom, that is the question.. Warren Shumway Care and Feeding of Molded Fiberglass Trailers 71 04-07-2012 04:28 PM
Replace Bigfoot Bathroom handbasin taps. Colin Plumbing | Systems and Fixtures 2 07-15-2007 08:45 PM
Bathroom possiblities Legacy Posts Care and Feeding of Molded Fiberglass Trailers 28 02-10-2003 07:36 AM
Dri Dek bathroom floor Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 10-04-2002 05:47 PM
