Battery blending - Fiberglass RV
Old 07-27-2007, 09:19 PM   #1
ronsmith100's Avatar
I put an extra battery in my casita
There was a sale on deep cycle marine batteries in Page (lake Powell boating). It is a sealed type... large amps I don't need but has a heck of a long sit-life.
The two are on a switch. OFF, 1, 2, both. (I am never going to click it to both probably as the two batteries are incompatible age and type and I cant go to off becasue - I think - it would be detrimental to the break away trailer brake stuff)
I charge the new big boy battery with a charger with a "deep cycle" setting.. I charge the Casita Battery through normal means (shore power and driving).
My question is,
1- can I tow with the new battery on?
2- can I plug into shore power with the new battery selected?
In other words will the casita's built in converter/charger charge that big duke without harm to either?
Ron
ronsmith100 is offline   Reply With Quote
Old 07-28-2007, 05:56 PM   #2
Pete Dumbleton's Avatar
The best answer you will get to converter questions is to call the converter manf with the model and serial #s off the ID plate. The egg manfs use off-the-shelf RV equipment, including the converters.
That said, quite likely the converter will charge either battery just fine, presuming they are just standard lead-acids at about 8 amps max. Don't leave either connected to the activated converter during long-term storage unless you KNOW you have a multi-stage smart charger with a float mode in the converter or you risk overcharging/wrecking them.
Likewise, if your switch is wired properly, either battery should charge when towing.
You are right, switch should be in 1 or 2, never Off when moving (brakes are likely fed from the batteries and you might check if it's both or just one) and never Both because if one batt is very dissimilar from the other, there may be problems.
battery
Hooking up boler battery to Tug battery Andy H Problem Solving | Owners Helping Owners 3 08-02-2007 12:59 PM
New Battery? Fred Bell Care and Feeding of Molded Fiberglass Trailers 13 06-30-2007 09:39 AM
Battery Box bonnie w Problem Solving | Owners Helping Owners 4 05-14-2007 07:22 PM
New Battery? Chris73 Problem Solving | Owners Helping Owners 7 06-15-2006 07:37 AM
Battery In or Out Steve L. General Chat 6 11-16-2005 08:26 PM
