battery charging question - Fiberglass RV
Old 07-23-2019, 11:48 AM   #1
Patricia D.'s Avatar
Trailer: 1975 Ventura
Manitoba
I need to use a battery charger to charge the deep cell battery in my trailer. Can I leave the various cables attached tot he terminals while charging or is it best to remove them?
Patricia D. is offline   Reply With Quote
Old 07-23-2019, 12:04 PM   #2
Raspy's Avatar
Trailer: Black Series HQ19, Oliver LE2
Smith Valley, Nevada
Leave them connected.
Raspy is online now   Reply With Quote
Old 07-23-2019, 12:48 PM   #3
Manitoba
Thank you. I know it must seem straight forward for most people but I was just not sure.
Old 07-23-2019, 01:11 PM   #4
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
+1 for leaving them attached.
Without adult supervision...
Also,
Old 07-23-2019, 01:36 PM   #5
Manitoba
secondary ques
When I charged the battery (not enough obviously) outside the trailer before putting it in and attaching everything up, I put a battery cable on the negative post and attached the negative to that, as directed in the battery charger manual. Do I do the same at this point?
Old 07-23-2019, 02:32 PM   #6
John in Michigan's Avatar
Yes, charger negative to battery negative, charger positive to battery positive.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 07-23-2019, 02:41 PM   #7
Raspy's Avatar
Patricia,
Try not to let your battery voltage get below 12.2 volts before you re-charge it. If there is a small constant load that runs the battery down when you are not using it, you can pull one of the cables off to hold the charge.
You can also get a battery tender that will keep it charged up when not being used. This will save your battery and allow it to remain hooked up.
Old 07-24-2019, 12:53 PM   #8
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
A smart charger will automatically cut back the charging amperage to maintain the full charge without over charging.
Another trick is to add a battery disconnect switch in the negative cable so the parasitic loads don't drain the battery while trailer is in storage. ( I did that because the battery in our Parkliner is inaccessible without removing the LP tanks.
If yours is easy to get at, just disconnect the negative, or ground, cable. - assuming you have negative ground system -
Any time you are disconnecting the battery, ALWAYS do the (-) post first.
that way, even if you touch your wrench to metal, while undoing the + post, it won't short out.
Old 07-24-2019, 02:04 PM   #9
I don't know why the negative lead should come off first or a disconnect switch in the negative when according to Kirchhoff's law it doesn't matter. For automobiles the frame is use to conduct current via the negative terminal which would cause a problem if the wrench used to disconnect a terminal managed to touch the frame while undoing the positive terminal while the negative is still attached. In case of fiberglass trailers it's not an issue.
Once the loop is broken that it.
Old 07-24-2019, 02:43 PM   #10
Raspy's Avatar
Fiberglass trailers have metal frames. Often the batteries are located too close to the tongue jack, which is metal and bolted to the frame. Or next to steel propane tanks that are sitting on metal brackets bolted to the frame.
Did Kirchhoff have any particular opinion about a grounded steel propane tank shorted to a positive battery terminal with a wrench?
Old 07-30-2019, 10:17 AM   #11
Trailer: '15 17' LD Casita and '17 Tahoe LT
Recently bought an upright charger with wheels from Sears before they shut down. The instructions now say to hook and unhook the positive cable first. I guess their thinking is that there is less chance of the battery being grounded when you hook up the positive first.
I have heard stories of mechanics grounding out their wedding rings while using a wrench on the positive pole and the wrench coming in contact with the frame.
dmad1 is offline   Reply With Quote
Old 07-30-2019, 10:30 AM   #12
jerrybob's Avatar
Trailer: casita
I agree Wayne....the battery disconnect is a great idea. Our trailer is on site here on our property....I keep her plugged in all winter with the battery disconnected. About once a month....I turn the switch and let the battery charge for 5/6 hours from shore power....this process keeps the battery fully charged and ready to go at any time. Been using this method for years and get many years out of the battery.
jerrybob is offline   Reply With Quote
Old 07-30-2019, 11:18 AM   #13
Trailer: 2013Escape 21
Iowa
My buddy Kirchhoff
He told me personally it was the quickest way to meet my maker should there happen to be a leak in the propane system.
Iowa Dave
Iowa Dave is offline   Reply With Quote
Old 07-30-2019, 11:45 AM   #14
B.K... get your voltmeter out, touch the positive lead the battery positive post and the negative lead to any bare metal on your trailer's tongue. Really.. do that before commenting further. If reading is zero, then you are correct for you.. it does not matter which terminal you disconnect first.
But for me, and most every Scamp owner out there, there will be 12 volts on the meter.
There are many people on this board who are newer and have not read many of your posts, and therefore don't know that your advice, equipment and camping (RV) lifestyle rarely is applicable to the majority.
Removing negative post first (or positive if pos ground system) can never hurt, but removing the positive post connection first with a negative grounded frame can hurt. I've grounded a wrench that way and once is all it takes to understand the common sense of removing the ground connection first.
battery
Battery Charging While Driving Question...? Boots Electrical | Charging, Systems, Solar and Generators 4 11-23-2011 09:56 PM
Battery charging question Joe in MN Problem Solving | Owners Helping Owners 5 09-25-2010 05:29 PM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
Battery charging question Kent I Problem Solving | Owners Helping Owners 4 12-29-2008 06:30 PM
Another battery charging question Sonny Care and Feeding of Molded Fiberglass Trailers 8 09-30-2006 08:14 PM
