Battery charging wire - Fiberglass RV
Old 06-13-2007, 09:53 PM   #1
Trailer: 74 Honey Boler
I'd like some clarification on how to run a power wire from my tug battery back to my harness. I thought I didn't have to, as I was going to splice into the 12V outlet at the rear of the vehicle but I am told the wire gauge isn't big enough to handle the current. Is that true? If it is, then how do I connect it? Do I just run a wire from the + terminal to the power line on the plug, then a wire from the negative terminal to the ground on the plug?
I'm no electrical whizz...
Thanks
J Martin is offline   Reply With Quote
Old 06-13-2007, 10:27 PM   #2
Trailer: 13 ft Scamp
Thanks
More than one inquiring minds want to know. I too am interested. Good question. Thanks for asking.
dsheets70 is offline   Reply With Quote
Old 06-13-2007, 11:24 PM   #3
John Perry's Avatar
Trailer: 1996 13 ft Scamp
Send a message via AIM to John Perry
I have a 10 gauge wire running from the tug battery to the trailer plug. I also have a 30amp circuit breaker in the line near the battery. The battery is already grounded to the vehicle so if you have a good ground at the recepticle on the tug and a good ground on the trailer side that should be good enough.
Remember to unplug your trailer from the tug when you are camping or you might find your tug battery is dead.
Hope this helps,
John
John Perry is offline   Reply With Quote
Old 06-14-2007, 12:07 AM   #4
Con
Trailer: 1977 Boler 1300/2003 17' Bigfoot
You have to install a battery isolation solenoid in addition to the 30 amp. circuit breaker.
That way you don't drain your tow vehicle battery. Most RV shops will have the solenoid.
Most of the newer vehicles in the last several years that come from with factory with the tow package are all ready pre-wired for the charging circuit and brake circuit.
They only thing you have to add is the right plug on the wires for your brake controller and plug it into the fuse box under the dash.
On the last 3 Chevy Z71 pickups I didn't have to wire up a thing, even had the 7 pin plug mounted.
On the older vehicles though you have to wire as up as I mentioned. And be sure to use the heavy gauge wire. While you are at, it run a wire for trailer brakes now even if you don't need it yet.
Con is offline   Reply With Quote
Old 06-14-2007, 06:01 AM   #5
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
Yup. I just did this. I used 12ga for the brake line (probably overkill) and 8ga for the charge wire. Whenever I get a new (to me) vehicle, I throw away the battery cables and make new ones from 1ga or 0/1 (depending on what I have lying around at the time). Including new grounds to the body, frame and engine... So far, I have no vehicles newer than '95 though so that may be unnecessary on newer vehicles. The fuse holder I had on hand wasn't water proof so I put it in a small waterproof container with 2 grommets for the wire. The brake wire and charge wire are sheathed in expandable cable shield and then the whole thing is attached to the truck...
We'll see how it holds up.
Herb P is offline   Reply With Quote
Old 06-14-2007, 08:44 AM   #6
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
I keep it simple and just do a 8-10 gauge wire and a 30amp fuse. Ground wire from hitch plug to suitable screw in rear bumper area (but weather proof.)
All you have to remember is to not keep your trailer plugged in while running your refrigerator on 12v! (Ask me how I know this! )
Patrick M. is offline   Reply With Quote
Old 06-14-2007, 10:23 AM   #7
It depends partly on what you want the battery/alternator to provide to the trailer. If you want it to be able to charge the trailer battery until it is fully charged, such as in half a day's driving, you may have to beef the wiring up.
Think of it as competing water pressures, one part coming from the tug battery/alternator and the other from the trailer battery. In order to charge, the pressure from the tug has to be greater than the existing "pressure" currently in the trailer battery. The greater the difference, the better the charging.
This is where the wiring comes in: inadequate wiring produces voltage drop, so by the time the tug voltage reaches the trailer battery it may be not much higher than the existing battery charge.
I found a section of my charge wire to be 12 gauge, it was not doing much. Changed it to 6-gauge with a 40-Amp Maxifuse near the alternator (hard to work with, requiring heavy lugs and different connectors to be practical), and the results exceeded my expectations. The alternator will now charge the batteries, run my frig and a towel warmer at the same time with ease.
If you really want it to work well, there is probably no substitute for hefty wiring.
Old 06-14-2007, 10:35 AM   #8
John Perry's Avatar
I am installing an isolator today. I recently purchased a slide in camper that makes it almost impossible to disconnect from the truck electrical system once it the camper is installed. If I was only using the trailer I would not have bought an isolator and saved the $45.00.
Old 06-14-2007, 12:38 PM   #9
Brian B-P's Avatar
Just a note on the "ground" connection...
That wire (normally white) and connection will carry all of the current for the trailer lights, battery charging (or running the refrigerator, etc), and the trailer brakes. That could be a lot of current, and (due to the lights and brakes) it is critical. I would not settle for the typical self-tapping screw in a random bit of steel - ran a 10 gauge wire (in hindsight it should be heavier) all the way from the 7-pin connector to the battery negative terminal. That wire also has a terminal bolted to the hitch receiver frame as a supplementary "ground" connection.
The comments about resistance to current flow apply equally to the "ground" side: you can have the heaviest cable sold for the positive wire, and the flow of current will still be restricted by the resistance of the negative (ground) wire and its connections.
Old 06-14-2007, 12:42 PM   #10
Brian B-P's Avatar
...Most of the newer vehicles in the last several years that come from with factory with the tow package are all ready pre-wired for the charging circuit and brake circuit.
They only thing you have to add is the right plug on the wires for your brake controller and plug it into the fuse box under the dash...
I think this is important: don't try to reproduce what may already be done for you.
Unfortunately many tow vehicles which are very capable of handling Class 1 (up to 2000 lb) and Class 2 (up to 3500 lb) trailers have no such wiring, including minivans and SUVs not based on truck chassis. Although kits to handle the lights are readily available, you're on your own for the brake controller and battery charging.
Old 06-14-2007, 12:57 PM   #11
Herb P's Avatar
I guess I have to disagree with you. I think a vehicle frame can probably carry more current than a 10ga wire. I think an 18" run of 1ga from battery to frame, and then an 18" run of 10ga from frame to 7 pin connector is going to have far greater current carrying capacity than a 20 foot run of 10ga... (As long as you address corrosion issues with the right kind of paste and preventative maintenance).
I will agree that a sheet metal screw into a piece of random steel is not going to do much but one can always find at least one way to do something incorrectly.
Old 06-14-2007, 01:13 PM   #12
Brian B-P's Avatar
Herb's right, of course, there's lots of metal in the vehicle structure. Who knows, maybe my return current is mostly flowing through the hitch then body then ground cable, rather than my wire... but there must be a good path, by whatever conductor.
I think we do agree that the "ground" connection -whatever the method - carries all of the current and is thus important.
Keep in mind that the body grounds which we see in vehicles when looking at the lighting and accessory circuits - which may indeed use a self-tapping screw - are designed for only a few amps, and you want to carry ten times more current.
Old 06-14-2007, 01:46 PM   #13
Patrick M.'s Avatar
And remember the ground wire (and the hot wire) in the 7-wire trailer connection carries all that current too, and God knows what size of wire that is!
Here's where I grounded my hitch connection. About 4' from the hitch, 10 gauge wire, high and dry.
Old 06-14-2007, 02:03 PM   #14
Thank you all for the info and especially the pictures. I ran out to Princess at lunch and bought some 8ga wire (on sale!) and loom to run it through. I am glad I only have to run one wire back from the battery. I'll try to ground the harness either on hitch or frame. What a wealth of knowledge here!
Jeff
battery
Battery charging paulitzlee2 Problem Solving | Owners Helping Owners 1 09-15-2009 10:12 PM
Battery Charging David G. Electrical | Charging, Systems, Solar and Generators 4 10-18-2006 07:47 PM
Battery re-charging wire Gerry Problem Solving | Owners Helping Owners 10 10-16-2006 08:41 PM
Battery Charging Wire? Chris73 Electrical | Charging, Systems, Solar and Generators 22 08-25-2006 11:20 PM
Battery Charging JOE DRISSEL Electrical | Charging, Systems, Solar and Generators 23 01-08-2006 03:03 PM
