Battery Connections - Fiberglass RV
Old 05-16-2007, 10:29 PM   #1
Trailer: Escape
I've read the various battery forums, but unfortunately, the knowledge is way beyond what I require. I disconnected my battery for the winter and stored it in my garage. Now I am trying to hook it up but it sparks every time I try to connect the second cable (I have the positive and negative marked correctly, at least). Is this normal? I've read enough to scare me from proceeding before hearing from somebody who knows more than me.
dlehman is offline   Reply With Quote
Old 05-16-2007, 10:37 PM   #2
Herb P's Avatar
Depends on the size of the spark. If it's a spark that leaves a dead spot in your retina for more than 10 seconds, then you have a problem, or you have discovered how to weld.
If it's a small spark like you would get if you rubbed your feet on the carpet and then touched a lamp, then that's just indicative of some electrons that are really eager to get out of the battery and into your wire (well, vice versa actually but ... )
Make sure all the switches and appliances in the trailer are switched off and you should have no spark... Nowhere for electrons to go, no spark.. Unless you keep a bank of capacitors in the trailer .....
Herb P is offline   Reply With Quote
Old 05-17-2007, 03:20 AM   #3
If your trailer is plugged in to AC power, the converter/charger is probably causing the spark (trying to charge).
Unplug the trailer before connecting the battery in addition to switching everything off as Herb P said.
Morgan is offline   Reply With Quote
Old 05-17-2007, 03:38 AM   #4
Trailer: Boler 13 ft
Herb is right, a little spark will be normal while hooking or unhooking the battery. If there is something trying to get power out or put power into the battery.
Don't worry but if your not sure if you have a slight short somewhere leave battery hooked up and test with multi-tester set for DC VOLTS and note the reading then being sure not to turn anything on test again the next day if reading is the same your A-OK
Gerry the canoebuilder
If not better start looking for a bare wire leaking power to the ground side.
Old 05-17-2007, 09:16 AM   #5
Trailer: Escape
Thanks for the information - I dropped out of engineering in college because I couldn't deal with electricity lab. Now, I understand that something in the trailer is trying to draw power. Since nothing is turned on, the AC is not plugged in, and I don't believe there are any shorts, I suspect it is the monitoring panel that is trying to get the power when I connect the battery. What I don't know is how to turn off that? Is there are master switch for all the power in the trailer?
Old 05-17-2007, 10:25 AM   #6
Brian B-P's Avatar
...What I don't know is how to turn off that? Is there are master switch for all the power in the trailer?
The ideas already presented here are all good.
This is an Escape? If I were down to this last question, and my trailer was from a company which was still in business (Boler has been gone for two decades) and was as responsive as Reace and his crew are, I would just ask them.
Old 05-17-2007, 10:34 AM   #7
Herb P's Avatar
Well, what you really care about is how much power is trying to flow across the gap when you connect the battery... A few hundred milliamp is not a big deal if it's only for a short time. It could be as simple as the capacitors in the 'monitoring panel' charging or something similar... It might draw a few mA for a few milliseconds and then that's it... If there's something drawing a few hundred milliamps indefinitely, then you have a parasitic load that will drain your batteries over time....
The trick is to hook up a multimeter between the battery and one of the battery leads, setting the multimeter in "A" (or current measurement) first. Then watch the meter. If it quickly goes down to 0, then everything's cool. If it blows a fuse inside the meter, then you have a short or the coffee maker is turned on...
You could also start by putting a light bulb on the battery post and touch the battery lead to the other side of the lightbulb. If the light bulb stays lit, then you have a draw of some sort. If the bulb flashes and burns a filament, check the coffee maker. It's just a quick inaccurate and cheap way to get an idea of what's going on before you blow a $25 fuse in your Fluke.
Old 05-17-2007, 03:37 PM   #8
Trailer: 94 Casita 16 ft
There's the voice of experience. I'd wager those fuses are a pain to replace too. lol
Paul from NWOnt is offline   Reply With Quote
Old 05-17-2007, 03:49 PM   #9
Herb P's Avatar
Oh no, Fluke makes them quite easy to replace. 2 phillips screws on the back of your meter... It's about $25 for the 20A fuse or while you're in there you can upgrade to the 1/4" 200A bolt for $0.12...
Old 05-17-2007, 06:06 PM   #10
Alf S.'s Avatar
Hi: If I wire anything up correctly the first time...it's a fluke!!! Alf S. North shore of Lake Erie
Old 05-17-2007, 08:45 PM   #11
Sounds much better then the Mastercraft equivalent, and I will definately consider the 12 cent upgrade.
The lightbulb as an ammeter never even occurred to me before, I'll be sure to pass this one on.
Thanks.
Old 05-17-2007, 09:20 PM   #12
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
WAIT just a seccy here.....somethings wierd?!?!
Anchorage Alaska and you have ~ A I R C O N D I T I O N I N G ~ ?
Tell me you at least live in SOUTHERN Anchorage, LOL!!!!!
Old 05-17-2007, 09:38 PM   #13
Herb P's Avatar
Please note, I was kidding about the 200A 1/4 bolt... That is a "bad idea™".
Old 05-17-2007, 10:18 PM   #14
Trailer: Escape
What makes you think I have air conditioning? I've still got snow on the ground.
Old 05-18-2007, 05:52 AM   #15
Herb P's Avatar
Because you said your air conditioner wasn't plugged in and you were wearing long pants:
Old 05-18-2007, 06:47 AM   #16
Gina D.'s Avatar
Tha AC, as in.. the power cord, silly! Alternating Current...
and I have a friend who would wear shorts in Alaska in the dead of winter...HE would have AC ....
Old 05-18-2007, 03:13 PM   #17
Doug Mager's Avatar
OOPSIE, I messed up A/C was NOT mentioned! Whatever was I thinkin about!!!
Old 05-18-2007, 06:36 PM   #18
Doug, Maybe you picked up on the AC at post #5....Benny
Old 05-18-2007, 08:48 PM   #19
Trailer: Escape
Final Resolution! Reace confirmed that there is indeed a spark - the propane detector draws enough current to trigger a spark. Unfortunately, the propane detector must be installed without a switch. So, my choices were either (1) ignore the spark (which I'm sure most people do, but all the advice about not having sparks near the battery scared me away from this), or (2) remove the fuse for the circuit that the detector was on. I did (2) and everything is now fine. I have all my limbs, my eyesight, and a trailer ready to go after 7.5 months of winter.
Given all the responses and lack of similar problems for others, I suspect that very few people actually disconnect their battery in winter.
Old 05-19-2007, 09:19 AM   #20
Victor Benz's Avatar
Hi I've done a number of trailer renos, and I have always hatred the "spark" at battery connect/disconnect since A horrible accident to a high school chum during a car boost. My solution is shown in the photo link below.
http://good-times.webshots.com/photo/25692...052473095msBkeC
To the upper right of my battery box, you can see a red handle of the keyed 12 volt swith I use. When I wish to disconnect or remove the battery, I first remove this key. I can then work in complete safety and comfort, no sparks. By the way, the tow vehicle cannot be connected either.
Vic
Victor Benz is offline   Reply With Quote
battery
NW connections....can you help? Penney H. & Mike E. General Chat 0 04-07-2010 12:50 PM
Connections to manufacturers Roy in TO General Chat 8 10-02-2008 03:00 AM
6 Volt Battery Connections VIDEO kevin61 Problem Solving | Owners Helping Owners 0 07-13-2008 04:28 PM
Gray water fittings and connections? Roy in TO Plumbing | Systems and Fixtures 4 06-02-2008 11:52 PM
Hooking up boler battery to Tug battery Andy H Problem Solving | Owners Helping Owners 3 08-02-2007 12:59 PM
