battery connections - Fiberglass RV
Old 04-16-2012, 10:55 PM   #1
Trailer: 13' scamp
battery connections
I am wondering what to use for a battery connection from the battery to where it splits off...?
It appears that the previous owner used a 110v 14gauge(3) wire,. and it got too hot...?
Spencer is offline   Reply With Quote
Old 04-16-2012, 11:10 PM   #2
David Tilston's Avatar
Spencer, please be very careful. The first thing you should know is that every wire must have an over current protection. This can be as simple as an in line fuse. It must be sized to the wire. This prevents the wire from becoming a fire hazard.
A quick search on google for a fuse table:
The DC Wiring Page - Connectors, Fuses and Wire
The 14 gauge wire should be good for lighting, and a fan. According to the table, 17 amps. Power is amps times volts, so 12 vdc x 17amps is 238 watts, not much. If you plan to power a 3000 W UPS, that requires much larger wire, preferably as short as possible.
Old 04-16-2012, 11:22 PM   #3
Batteries normally are 2 gauge wire to take the battery load.
battery
What is the purpose of internal battery connections? jordo Problem Solving | Owners Helping Owners 10 10-17-2011 04:57 PM
NW connections....can you help? Penney H. & Mike E. General Chat 0 04-07-2010 12:50 PM
Connections to manufacturers Roy in TO General Chat 8 10-02-2008 03:00 AM
6 Volt Battery Connections VIDEO kevin61 Problem Solving | Owners Helping Owners 0 07-13-2008 04:28 PM
Battery Connections dlehman Problem Solving | Owners Helping Owners 19 05-19-2007 09:19 AM
