Battery disconnect and volt meter - Fiberglass RV
Old 05-28-2015, 05:12 PM   #1
Terry M's Avatar
Illinois
I installed a Drok 0.40 waterproof digital volt meter and a Moller #042221910 battery disconnect switch on the battery box of my Scamp 13. Both $13 from Amazon. Easy installation, and both work great. I switched the positive battery lead and hooked the volt meter to the switch so I can turn everything off, including the meter LED display so it does not drain the battery even though it is very low ~ 0.4 milliamps draw. I installed the volt meter in the battery cover and spliced in a two pole trailer plug so I can disconnect the leads to remove the battery cover. The switch was installed in the end of the battery box, I have a group 27 battery and there is plenty of room for the switch installation but I did put a couple of 2x2 inch blocks on each side of the switch to keep the battery from shifting and contacting the switch. I made all of the cut-outs in the battery box with a utility knife and after installation I ran a bead of RTV along the inside edge of the cut-outs. I checked the accuracy of the meter; the meter display read 12.0 v and my Fluke meter read 12.05 v. I tried to post a picture but think it is lost in cyber space. Terry M
Terry M is offline   Reply With Quote
Old 05-28-2015, 05:14 PM   #2
Terry M's Avatar
Illinois
Battery Disconnect Switch
I guess the picture did get attached, here is another view. TM
Old 05-28-2015, 05:39 PM   #3
rbryan's Avatar
Arkansas
Very nice. Functional and simple.
battery
dumb question about volt meter VicCT Electrical | Charging, Systems, Solar and Generators 39 04-16-2014 07:13 AM
Heavy Duty Battery Disconnect FTTRV Commercial Posts and Products 2 11-26-2013 09:36 AM
Volt - Amp Meter Darwin Maring Electrical | Charging, Systems, Solar and Generators 2 07-12-2013 11:36 AM
Looking for a Good Volt/Amp Meter curtis c Problem Solving | Owners Helping Owners 4 05-13-2009 08:09 PM
Battery Disconnect Switch Victor Benz Electrical | Charging, Systems, Solar and Generators 18 07-06-2006 04:33 AM
