Old 05-31-2011, 10:18 PM   #1
Karalyn's Avatar
Trailer: Eggless for now;-( currently own Starcraft AR-ONE and Amerilite 21 ft
Battery, do I need one if plugged into electricty?
I have a Scamp - If I want to run the furnace, fridge, or the bathroom pumps do I need a battery if I am plugged into electricity? I know some lights run off battery only, but what about the other stuff.
My battery died and I am wondering if I really need to buy one if plugged into electricity?
Thanks in advance for any insite you may have.
Old 05-31-2011, 11:14 PM   #2
Trailer: 2006 Scamp 13'
There are only two electrical systems in Scamp trailers. One the 120 volt system that runs the converter, maybe a light, and maybe the fridge. The battery or converter supply power to the 12 volt system. There are no lights that run off the battery only unless somebody has mess with the wiring.
Old 06-01-2011, 12:57 AM   #3
BobB's Avatar
Hi Karalyn,
You can operate the electrical system with the battery removed, but you should make sure the positive battery cable cannot touch anything conductive, which might cause sparks and a fire. You can check the positive cable with a test lamp or voltmeter while the trailer is plugged into shore power. If it is hot, thoroughly wrap the positive cable with vinyl electrical tape to prevent any sparks.
Old 06-01-2011, 01:02 AM   #4
Roger C H's Avatar
There is the case of the electric brakes breakaway switch not working without an onboard battery...
Old 06-01-2011, 08:54 AM   #5
Trailer: 2002 Casita 17' Spirit Deluxe
I have heard it is hard on you converter? Not sure if its true or not.
iplumb is offline   Reply With Quote
Old 06-01-2011, 10:09 AM   #6
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Byron, are you sure about that?
Old 06-01-2011, 12:45 PM   #7
Scamp wiring diagram
Old 06-01-2011, 02:31 PM   #8
Trailer: 2005 13 ft Trillium Outback
The converter will try very hard to charge the non-existent battery. It will keep pushing it's maximum DC voltage nowhere. I'd recommend disconnecting the converter if you aren't going to have a battery. But then you won't have the water pumps either.
I'd strongly recommend that you have a battery for the bathroom water pumps and to make life easier for your converter. Is the trailer wired to get 12 volts from the TV? Do you have electric brakes on the trailer?
You could go with a marine/rv group 24 battery since you are not planning to need it for extended stays.
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Curtis F. is offline   Reply With Quote
Old 06-01-2011, 08:06 PM   #9
Karalyn's Avatar
Thanks everyone. You have talked me into getting a replacement battery. Better to be safe than sorry.
Old 06-05-2011, 05:22 PM   #10
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
Karalyn,
We had to replace our battery too. L&M Fleet has group 27 Deep Cycle Battery on sale for $56.75. 27DC-5 SKU #1270039. (all prices with exchange)
You need to check the size of your battery box. We had a 27 in our Scamp already. You may not have that large of a box and need a 24.
Too bad, we got ours before the sale. Sale ends June 11.
Nancy
Nancy is offline   Reply With Quote
Old 06-21-2012, 06:13 AM   #11
Susanm34's Avatar
Name: Sue & Gene
Trailer: 1989 Scamper 16ft
Illinois
We have a 1989 16ft Scamp Deluxe-we are just now starting to experiment with using the battery. It seems a few lights will operate, but thats it. Any suggestions on troubleshooting--we are wanting to be able to operate our electric water pump and maybe an outlet for a fan.
Gene & Sue
Illinois
Susanm34 is offline   Reply With Quote
Old 06-21-2012, 06:54 AM   #12
Thomas G.'s Avatar
Trailer: UHaul CT13 TV: Escape Hybrid
SE Michigan
Looks like you have an answer in the other post you made with the same question.
Just call me Tom.
Old 06-21-2012, 02:22 PM   #13
Trailer: scamp 13
i'll tell you from my perspective having just spent a week dry camping with my fridge running on propane my battery kept me in lights and occasional use of my fan for the week and only on the last day was it pooped out. and that was after running the fridge on 12 volt for 8 hours.
Old 06-21-2012, 05:41 PM   #14
Gene & Sue
Illinois
Something doesnt sound right. On my Scamp everything including the water pump runs off the battery except the one long kitchen light.
battery
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving -- Owners Helping Owners 2 08-25-2010 01:44 PM
Help dead battery & still no lights plugged in- Mark J Problem Solving -- Owners Helping Owners 8 12-09-2009 04:15 AM
Problem with lights while plugged in... Monica M Problem Solving -- Owners Helping Owners 12 04-20-2009 09:35 PM
Hooking up boler battery to Tug battery Andy H Problem Solving -- Owners Helping Owners 3 08-02-2007 12:59 PM
Do you leave your brake controller plugged in? Gina D. Problem Solving -- Owners Helping Owners 7 06-20-2006 12:47 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
