Battery Issue with newly purchased Bigfoot trailer - Page 2 - Fiberglass RV
Old 12-04-2015, 10:37 AM   #15
Raff's Avatar
Originally Posted by tractors1 View Post
Unplug the tow when camped until you can get an isolation relay installed on the 12V charge line.
One of these will save you from a dead battery in your tow vehicle
Name:	ImageUploadedByFiberglass RV1449250642.480851.jpg
Raff is offline   Reply With Quote
Old 12-22-2015, 01:43 PM   #16
Bigfoot1992's Avatar
Trailer: Bigfoot/Boler
Thanks for all the good info. I have to wait for shop appt. in Feb. as this BF family is not DIY savvy. Will let you know diagnosis - tech didn't think it would be too serious, mentioned it might just be corrosion. Digits crossed but we're in it for the long haul either way. Have site booked for right after check up - excited to actually use it.
Bigfoot1992 is offline   Reply With Quote
Old 12-22-2015, 08:26 PM   #17
Ken, A blown inline fuse is a pretty common issue. Checking the inline fuses either just off the battery (if there is one) or the one in the house is pretty easy as has been suggested. Often they are wrapped up with electrical tap and the wire itself will be a bit fatter where the fuse holder is making them easy to spot. No need to wait for a pro.
Old 12-22-2015, 08:36 PM   #18
I don't know about big foot but my Scamp has a fuse near the battery. It's in an inline holder. From your description of the problem It sounds like that could be the problem. The other issue could be the battery is connected backwards which would explain the dead tow vehicle battery.
Old 12-22-2015, 08:49 PM   #19
As Byron suggests hooking up the battery incorrectly is also common. Hooking up incorrectly can also result in a fuse issue as well.
It should be if wired as original:
Positive to Black Wire and Negative to White wire.
battery, bigfoot
Painting a newly acquired Croft FG trailer Reed Care and Feeding of Molded Fiberglass Trailers 23 04-29-2017 12:01 PM
PURCHASED!! Looking for Bigfoot or Trillium 17' - 18' Deadhead517 Classified Archives 19 11-10-2014 06:24 PM
Newly retired traveling in Lance truck camper plaman Hi, I am.... 7 10-28-2014 07:00 AM
Feeling (newly) Scamperous... John in Seattle Hi, I am.... 2 06-22-2013 06:55 PM
SOLD - Newly Restored Amerigo Slide In Gerry Classified Archives 2 12-10-2006 06:59 AM
