Battery Issue with newly purchased Bigfoot trailer - Fiberglass RV
Old 12-03-2015, 04:22 PM   #1
Bigfoot1992's Avatar
Trailer: Bigfoot/Boler
We were so excited to purchase our 1992 15B17G bigfoot that we probably overlooked a few issues. Hoping this one is not too serious. Here's scoop:
The Trailer lights do not work using 12V battery. (initially we chalked that up to requiring a new battery but replacing the battery didn't fix the problem.
We referred to an online Owners Manual which mentions a battery disconnect switch. We don't have the manual for our older model but we sure couldn't find such a switch. Does anyone have a similar age of Bigfoot/owners manual that could confirm not all Bigfoot trailer have disconnect switch.
Also - our Grand Cherokee's battery was completely drained. We had left the trailer hooked up overnight. (throwing that in there in case it's all related and some smart person has some answers). Thanks
Bigfoot1992 is offline   Reply With Quote
Old 12-03-2015, 04:47 PM   #2
Trailer: 1993 CASITA 16SD
Do the 12v lights work when you're hooked up to shore power? Do you have a refrigerator that's set to 12v power?
CASITA BANANA is offline   Reply With Quote
Old 12-03-2015, 04:56 PM   #3
Yes - lights work when plugged into electricity. 2 way fridge - LP/Electric - does not run off battery. Any thoughts?
Old 12-03-2015, 05:24 PM   #4
Most likely, your 2 way LP/Electric refrigerator is a newer unit that requires 12 volt power to run the electronic igniton and thermostat control.
Old 12-03-2015, 05:32 PM   #5
There might be an in line fuse in the wiring where it comes into the trailer. It would be under the left side dinette seat along the front bulkhead. A previous owner could have installed a fuse or disconnect close to the battery, or the battery may be dead.
Old 12-03-2015, 05:37 PM   #6
Trailer: 1993 Bigfoot 17 ftCB / 2003 Honda Odyssey
Bigfoot main fuse.
The Bigfoot has a Main Fuse located at the cable entrance from the Battery under the front driver's side Dinette Seat, near the Hot Water Heater (if installed) inside the trailer. It may be taped up partially, on the cable, or very hard to find but it's there. It is probably corroded or, maybe, the 30A fuse is just blown.
I'll bet that's the problem as it will separate the tongue battery from the internal system. Also, if the converter is still the Magnatek 6300 unit, you should plan to replace it ASAP. There are many other manufacturers replacements and or, even an upgrade kit (which I don't at all recommend).
Do a Google search for Magnatek Replacements or even a search on this usegroup and you will find a few threads on this.
Good luck.
Mike .....>
Michael Pupeza is offline   Reply With Quote
Old 12-03-2015, 06:44 PM   #7
Trailer: Class A Motorhome
As other expect this answer I won't disappoint.
Although nothing suggests that you need a need a new converter, you might consider the Progressive Dynamics PD-4045 mini power center. It combines an A/C distribution section, a 45 amp converter, and a 3 stage smart charger. I have installed a number of them, as have others on this site, without any problems.
But yes, if you have an original Magnatek unit, it is time to upgrade.
Old 12-03-2015, 07:47 PM   #8
Correct me if I'm wrong but doesn't the converter convert the 120v to 12v making it possible for the 12v lights to work under shore power?
Old 12-03-2015, 08:15 PM   #9
Yep, but it also has to charge the battery when plugged into shore power.
Old 12-03-2015, 08:51 PM   #10
I have the original manual that came with my 94 Bigfoot. The original owner was one of those guys that saves everything. When it comes to electrical information it is 100 % useless. In all other areas it is 95 % useless. You'll get better information from forum members.
Old 12-03-2015, 11:53 PM   #11
92 and 97...
first thing to keep in mind is that "somebody" has had 23 years to do some changes to your electrical system since it left the factory...so manuals, at best, will only give you some clue as to the extent of the changes, if any, were made and where.
My 97 is close enough in age that the general arrangement should be the same as yours. Mine is a CB model however....I'm thinking your layout will make it easier to figure things out....
as stated before you should be able to find a main fuse ("coach fuse") under the left dinette seat....in that bundle of wires that comes in through the floor there should be an obvious larger black and white wire...the fuse (barrel type, in a plactic holder) should be a foot after the run enters the trailer....on the black wire
from there those two wires (in my trailer) are part of a bundle of wires fastened to the floor....it was difficult to do but I traced these main wires...instead or running to the power center which is right there under the same seat, they run towards the back of the trailer and "dissapear" behind my bathroom and after that my fridge!!!! somewhere back there they are connected/power the ceiling lights of the trailer (more !!!)....the ceiling lights are therefore "main fused" only.....a second set of black/white wires comes back from the rear of the trailer somewhere and enter the power center/connect to the two blocks on the DC fuse panel.....I know it sounds odd but that the way it is on my trailer and it looks very much "original"...
since you do not have a bathroom right there you might find it easier to trace these wires on their "return trip to the back" before making it to the power center...lemme me know what you find out.......good luck
Old 12-04-2015, 09:37 AM   #12
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
1] Does your converter have a manual switch from 12V to 120V ?
2] Does the battery in the trailer go dead when the vehicle battery dies ?
3] Since something is killing the battery it is necessary to find the cause , it could be the fridge , could be the battery to battery connection , or a dead short somewhere in the system.
Bob in Mb is offline   Reply With Quote
Old 12-04-2015, 10:30 AM   #13
tractors1's Avatar
Trailer: Escape 21 - Felicity
Unplug the tow when camped until you can get an isolation relay installed on the 12V charge line.
Charlie Y
Old 12-04-2015, 11:35 AM   #14
Raff's Avatar
I put a PD-4045 in my Boler. Well worth it
Name:	ImageUploadedByFiberglass RV1449250474.985282.jpg
Raff is offline   Reply With Quote
Old 12-04-2015, 11:37 AM   #15
Raff's Avatar
One of these will save you from a dead battery in your tow vehicle
Name:	ImageUploadedByFiberglass RV1449250642.480851.jpg
Old 12-22-2015, 02:43 PM   #16
Thanks for all the good info. I have to wait for shop appt. in Feb. as this BF family is not DIY savvy. Will let you know diagnosis - tech didn't think it would be too serious, mentioned it might just be corrosion. Digits crossed but we're in it for the long haul either way. Have site booked for right after check up - excited to actually use it.
Old 12-22-2015, 09:26 PM   #17
Ken, A blown inline fuse is a pretty common issue. Checking the inline fuses either just off the battery (if there is one) or the one in the house is pretty easy as has been suggested. Often they are wrapped up with electrical tap and the wire itself will be a bit fatter where the fuse holder is making them easy to spot. No need to wait for a pro.
Old 12-22-2015, 09:36 PM   #18
I don't know about big foot but my Scamp has a fuse near the battery. It's in an inline holder. From your description of the problem It sounds like that could be the problem. The other issue could be the battery is connected backwards which would explain the dead tow vehicle battery.
Old 12-22-2015, 09:49 PM   #19
As Byron suggests hooking up the battery incorrectly is also common. Hooking up incorrectly can also result in a fuse issue as well.
It should be if wired as original:
Positive to Black Wire and Negative to White wire.
battery, bigfoot
Painting a newly acquired Croft FG trailer Reed Care and Feeding of Molded Fiberglass Trailers 23 04-29-2017 12:01 PM
PURCHASED!! Looking for Bigfoot or Trillium 17' - 18' Barb and Alan Classified Archives 19 11-10-2014 07:24 PM
Newly retired traveling in Lance truck camper plaman Hi, I am.... 7 10-28-2014 07:00 AM
Feeling (newly) Scamperous... John in Seattle Hi, I am.... 2 06-22-2013 06:55 PM
SOLD - Newly Restored Amerigo Slide In Gerry Classified Archives 2 12-10-2006 07:59 AM
