Battery - Not Working - Fiberglass RV
Old 06-16-2006, 12:55 PM   #1
Jeremy Witt's Avatar
Trailer: 2005 Scamp 13 ft
Hello,
This is the second summer we have been camping in our Scamp. This spring, I charged up the battery, that had been stored all winter. When I put it back in the Scamp, I unknowingly hooked the wires up to the wrong terminals on the battery. The colors seem backward, but then I saw sticker that said otherwise. Anyway, now nothing works on battery.
Is it dead? Or did I blow a fuse?
Everything works fine when plugged in.
Thanks!
Jeremy Witt is offline   Reply With Quote
Old 06-16-2006, 01:37 PM   #2
Suz
Suz's Avatar
I'm not positive but I think most of the batteries in our trailers (especially the newer ones) have an inline fuse to keep from blowing the system. Mine is close to the battery. I'd check that first.
A quick call to Scamp might be the best for a quick answer.
Suz is offline   Reply With Quote
Old 06-16-2006, 03:25 PM   #3
Trailer: 1981 13 ft Scamp
Lights don't care if the current is reversed. Motors run backwards if +- are wrong, so maybe no harm no foul. Just don't run water pump! Or radio either.
shirley munson is offline   Reply With Quote
Old 06-16-2006, 03:39 PM   #4
Gina D.'s Avatar
West Coast USA
It is more likely you blew a fuse than ruined your battery. Thats what they put them there for.
Simple things first.. check your fuses.
Power supplies of items ARE sensitve to reversals and on the cheap stuff, they are not protected, generally. Or they are internally fused in one way or another, and not real user fixable. If nothing was on when you misswired, they probably were not harmed, a fuse on your 12v line just went.
Did anyone mention to check the fuses?
Old 06-17-2006, 06:16 AM   #5
jrnutpaul's Avatar
Trailer: 1994 20 ft Bigfoot 5th Wheel / Toyota Tacoma SR5
I'm not sure about what I'm going to say, but there may be two inline fuses between the battery and your converter. The first should be on the positive wire a few inches from the battery terminal. The second fuse is somewhere inline within the trailer. I've read on this forum that it may be hard to locate. In all probability a fuse is all that has gone wrong. In my unit, if I hook up the wire in reverse 1 or 2 30amp fuses will blow at the converter.
Paul
jrnutpaul is offline   Reply With Quote
Old 06-17-2006, 05:49 PM   #6
Jeremy, did you do a load test or a voltage test on the battery proper? I believe that depending on how long, and what was hooked up, it possibly drained the battery down completely....it possibly wouldn`t blow the fuses since you only reversed the polarity and if there was no short, or high current drain, then the fuse doesn`t know that there is a problem.....Benny
Old 06-17-2006, 08:52 PM   #7
Trailer: 1998 13 ft Scamp
Benny is right. The fuses in the trailer itself will not open from reversed polarity. I don't know any thing about converters, but it may have a protective feature that opens a fuse when the battery is wired wrong. This was Paul's experience. But I don't see why this would prevent the trailer lights, etc. from working.
I would do the load check on the battery before anything else. An auto parts store should be able to do this for you.
Sonny is offline   Reply With Quote
Old 06-17-2006, 09:08 PM   #8
Gina D.'s Avatar
West Coast USA
Unless it arced.
Don't ask me how I know this.
battery
Fridge not working on AC Parker Buckley Problem Solving | Owners Helping Owners 11 12-04-2009 09:53 PM
DC lights working with no battery connected???? dora D Problem Solving | Owners Helping Owners 4 10-10-2007 06:17 PM
Hooking up boler battery to Tug battery Andy H Problem Solving | Owners Helping Owners 3 08-02-2007 12:59 PM
Who's working, anyway? David G. Jokes, Stories & Tall Tales 8 01-23-2007 11:42 AM
Working paradoxes Morgan Jokes, Stories & Tall Tales 8 12-08-2005 11:17 AM
