Battery position / location - Page 2 - Fiberglass RV
Old 10-04-2008, 09:14 PM   #15
Howdy, I have my battery and propane tank side by side......battery mounted on a steel tray in a battery case and a steel cable and lock to keep it in place....propane tank was moved over a bit and it also has a steel cable looped thru the tank handle.....tank held in place by two hold downs.....you can see it on my webshots site....Benny
Old 10-10-2008, 03:46 AM   #16
Trailer: Boler 13 ft / 31 ft Holiday Rambler
Maine
I am new to camping in an Egg, so I am not sure what my consumption will be. The propane will be used mostly for the Fridge and heater/furnace when reguired. I plan on putting a quick disconenct outside the trailer to plug a portable bbq in. There may be times when I would be using the trailer with no hook ups for 4-5 days. That's how it came and I just assumed that's what I needed. Any idea of average consumption?
As a camp ground host I've had my fridge, running on propane 24/7 and the heater at night going now that it is fall and a 20# has lasted me going on 21 days now so one tank is more then enough.
My Boler also had no battery hook up but I installed one inside for the 1'st year then wanted the room for storage so I placed it on the tounge.
A metel frame to fit the plastic box was welded onto the frame of trailer close to Jack.
I then bent a 1/4 rod, threaded ends go through holes in bottom frame, to go over box to hold in place. (see red in attachment)
The propane sits behind this.
Gerry
battery
Bigfoot battery location Legacy Posts Problem Solving | Owners Helping Owners 16 08-23-2010 11:09 PM
campground manager position Sebastian H Fulltiming in a Molded Fiberglass Trailer 48 03-09-2009 03:42 PM
Battery location in Campster Bobbie Mayer Problem Solving | Owners Helping Owners 4 08-08-2007 09:45 AM
Battery location Dan Simon Modifications, Alterations and Updates 39 05-27-2006 10:22 AM
