Battery power for an Atwood Furnace - Fiberglass RV
Old 11-29-2009, 12:29 AM   #1
Mac B's Avatar
Trailer: 2000 14 ft Widebody Burro / 1998 Land Rover Discovery
I have an Atwood furnace in my Burro, as best as I know it's a 12K btu unit (but possibly larger, like 18K)
I am wanting enough battery power to run it for a number of hours at a time for dry camping. As my experience has been so far, if it's cold enough to need a furnace, it'll have to run more than just a few minutes and I don't want the battery to wimper out on me in the middle of a cold night! So I am thinking about adding another battery, and getting a generator to charge the batteries. I would hope that two batteries should be enough. For a generator, I'd love to get a honda 2000 but I don't want to over kill it (especially since they are over $1,000.00)
Who can sign the 'been there done that' log, and can give me some good advise, as to battery power and ample generator?
Mac B is offline   Reply With Quote
Old 11-29-2009, 01:09 AM   #2
Raya's Avatar
Mac,
How many amps does your furnace fan draw? Knowing that would help to calculate what size battery bank you'd want (assuming you don't want to run the generator in the middle of the night).
And how many days/nights would you want to be able to run the furnace between battery recharges?
I know you'll have to guess at how much of the time the furnace is running in a given 24-hour period, but knowing how many amps fan draws is a place to start the calculations. It makes more difference to the electricty side of things than how many btus the furnace puts out.
Raya
Old 11-29-2009, 01:11 AM   #3
Mac B's Avatar
Honeywell HW2000i 2000-Watt Portable Inverter Generator
Sear, $699 (those bandits)
Wallyworld $549.00
Old 11-29-2009, 01:13 AM   #4
Mac B's Avatar
I didn't see your post before I added my 2nd one
I figure that battery recharge during the day would be ok...
as far as the amps, I will have to call and ask the RV company
Mac,
Raya
Old 11-29-2009, 01:51 AM   #5
Raya's Avatar
Mac,
I think it might be on the fan, and/or listed in the manual. Do you have the model number for the furnace?
Okay, I asked about how long you'd want the furnace to run because I thought there were some campgrounds where generators weren't allowed. But maybe that's only at night, so you could count on charging every day
Once you have the fan draw, then we can calculate for worst case scenario and work back from there.
Raya
PS: Another thought, if you are thinking about setting up a battery bank and generator just for the furnace fan, is one of the Wave catalytic heaters. I think the 6 is the larger one. They run on propane only and hence use no electricity.
It just seems a shame to use propane, electricity and batteries, plus gasoline for an internal combustion engine in a generator, just to run a furnace fan! Which is not to say that you shouldn't do it, but just to share ideas.
Old 11-29-2009, 05:08 AM   #6
Yvon Chayer's Avatar
Trailer: Bigfoot 17 ft 1992
Quebec
In my Bigfoot i have the same furnace as you and for example at the tankgiving in Canada we have a snow when we camped for the last time this year
I have just one optima battery ( 4 years old ) in my Bigfoot and after one total day of heating the battery was half full
I have an electronic thermostat on the furnace , the furnace dont run longtime but run often
I run the generator an average of one hour per day to recharge the battery via my converter ( intellilli-power)and i am ready for the next cold day
PS I love my honda 2000i i can run small window ac in hot day with no problem but i use the ac small amount i prefer the maxair fan in hot day
Yvon Chayer
Yvon Chayer is offline   Reply With Quote
Old 11-29-2009, 06:43 AM   #7
BobB's Avatar
We have an Atwood heater and a group 27 battery in our Bigfoot. We have never run the battery down camping 3 or four days in the same spot without shore power. The same was true of our Casita/Suburban set-up. We have a good charging system in our Jeep, so we always start with a fully charged trailer battery when we arrive at the campsite. If you are really concerned about loss of power, a spare battery is a lot cheaper than a Honda Eu2000i. If you decide to use a second battery in parallel, the 2 batteries should be matched, including age. Otherwise, you would just changeover to the fresh battery when the first becomes depleted.
Old 11-29-2009, 09:29 AM   #8
Marty Smiltneek's Avatar
Trailer: 1972 Boler American
Wisconsin
The best you can do is a good estimate because of all the variables in the system. The whole heating system includes the camper it is mounted in.
After a bit of research - - - The atwood 8012 draws 1.8 AMPS [at] 12 volts and the more common 7912 through 7919 series draws 3.4 AMPS [at] 12 Volts.
I would assume you have the 7912-II that draws 3.4 Amps per continuous hour of run time.
If the furnace runs twice an hour for 10 minuits each time would be a total useage of about 1.2 amp hours. Divide the total amp hour usage into your battery rateing of say 24 amp hours. The result would be a run time of 1 full day.
recap:
you need to know the amp hour draw of your furnace. (this is the actual measured current draw for a full hour of running)
The amount of time it actually runs. (Things that effect this are: how cold is it outside. how often is the door open, how good is the insulation, is the roof vent open all the way, window seals etc. etc. and on and on)
The amount of overhead the system thermostat uses (mostly 0 if passive or AA battery sourced).
The size of your battery in amp hours total capacity, (Don't forget that the battery looses capacity with age).
I think that any calculation is a good guess at best. You will need actual experience to find the answer and that will change with wind, temperature etc. Good luck with that!
Marty Smiltneek
Marty Smiltneek is offline   Reply With Quote
Old 11-29-2009, 09:33 AM   #9
Wisconsin
Oh, yeah - - - I forgot that the capacity of the battery is diminished by cold temperatures I think that the battery manufacturer has a chart reflecting the effect of temperature.
Also if you fully discharge the battery it can freeze and crack in really cold temps.
Marty
Old 11-29-2009, 12:36 PM   #10
Raya's Avatar
Another good idea is to only plan to use about 50% of your battery's rated amp hours. You can draw it down further (say, 70%), but the more often you draw it down further, the shorter the life of the battery. So I would plan to only use 1/2 the amp hours in a given battery (or batteries) when making my calculations. Then plan to re-charge before drawing down to 50% again, etc.
Raya
Old 11-29-2009, 11:26 PM   #11
Mac B's Avatar
thanks for all the replies... yes, it does seem a shame to have to use battery power, propane AND gasoline for a generator just to run a fan motor!
I do have a series 27 battery.
I downloaded the Atwood furnace manuel... so I see where it draws 3.4 amps. I can't say I understand all these calculations though.
Old 11-29-2009, 11:29 PM   #12
Mac B's Avatar
ps.. I am asking all these questions because I took a trip to Yosemite and in one night, still hooked up to my tow vehicle, useing the heater, I depleted my battery..... my vehicle would barely crank over. And I am planning a trip (in June) to Alaska. I want to be prepared!
Old 11-30-2009, 12:31 AM   #13
Raya's Avatar
Okay, well, if the manual says it draws 3.4 amps, that means that it draws that much each hour that you have it running. In other words, 3.4 amps per hour.
Let's say your Group 27 battery has a capacity of 100 amp-hours (it should say on it, but this might be close). For starters, it's good to not drain your battery more than about 50% on a regular basis, for longer overall life. So say you have 50 amp-hours to work with (of course you can draw the battery down more if you have to, it's just not the healthiest over the long term).
Now, if you run your furnace only at night, and "night" is 9 hours, and it runs....oh, I'm just guessing... but say 30% of the time, that's about 3 hours of fan running. 3 hours x 3.4 amp-hours = 10.2 amp-hours. So, if that's all you have attached to that battery, then you will be down about 10 amp-hours for each night that you run the furnace. Then theoretically you would be able to run the furnace 5 nights and still only have taken about 50 amp-hours out of your battery, which is that 50% depleted level.
Now you have to put 50 amp-hours back in, one way or another. By electric charger, by internal-combustion generator, by solar panel, by wind generator, etc. (And of course you don't have to wait until this point to start charging.)
Does that make sense?
(The one thing that is really a guess is the part about the furnace running 3 hours in a 24 hour period. That may be low. Do you have a sense of how many hours it ran when you were in Yosemite? And what the temperature and wind speed were?)
Raya
PS: Edited to change amps to amp-hours.
Old 11-30-2009, 01:41 AM   #14
Mac B's Avatar
yes, that makes sense. I must have something wrong with my system if in one night it drained the battery. I doubt if it ran a whole 3 hours during the night. I may have to have the system checked to see if it is charging properly.
battery, furnace
Problem with Atwood furnace JPraeder Problem Solving | Owners Helping Owners 8 06-06-2013 06:30 PM
Atwood furnace new on Trillium..won't kick on...fuses fine.... lloyd cicetti General Chat 15 04-12-2010 08:21 PM
How Long Will a Battery Run the Furnace? Karalyn Problem Solving | Owners Helping Owners 15 05-06-2009 06:26 PM
Ensolite Seams and Furnace Power Questions Tim Black Problem Solving | Owners Helping Owners 7 05-04-2009 09:56 PM
Battery power question Sharon Herman Care and Feeding of Molded Fiberglass Trailers 31 03-30-2006 09:39 PM
