battery switch - Fiberglass RV
Old 06-22-2007, 02:58 PM   #1
With two deep cycles installed now, how can I switch between them? Is there an inexpensive rotary switch?
RD
Ron Davis is offline   Reply With Quote
Old 06-22-2007, 03:32 PM   #2
Pete Dumbleton's Avatar
Many RVers just leave them both on-line together unless they are somewhat different in age, constuction, etc.
However, if you want to switch between them there are numerous (sparkless) switch configurations available from marine supply places like West Marine.
Be very sure that you NEVER have a situation where you disconnect all batteries from a running alternator or you will likely have expensive damage.
Old 06-23-2007, 08:50 AM   #3
Wallyworld sells a switch that goes on the negative side of the battery. It has a green round knob on top and sells for around $5USD.
I would think that you could connect the 2 Positive terminals together then run a ground strap from the frame to the negative side of the switch, on each battery, then you could turn off either battery as you please.
You would not connect the negative terminals together.
That would be 2 ground straps. Each battery would have one of those green disconnect switches installed on the negative terminal and the ground strap to the frame.
Old 06-26-2007, 08:50 PM   #4
Joe MacDonald's Avatar
look for perko or bluesea switches, it is very common to find a/b or "a and b" switches for marine use.
I think even Cabelas has them.
battery
Wuz there a switch somewhere?? Doug Mager Ft. Langley B.C. Rallies 4 05-15-2009 11:14 PM
Hooking up boler battery to Tug battery Andy H Problem Solving | Owners Helping Owners 3 08-02-2007 12:59 PM
Is it ok to mount a battery isolation (cut off) switch inside the trai Curtis F. Problem Solving | Owners Helping Owners 8 07-05-2007 06:46 PM
Battery Disconnect Switch Victor Benz Electrical | Charging, Systems, Solar and Generators 18 07-06-2006 04:33 AM
battery switch Ron Davis General Chat 0 12-31-1969 07:00 PM
