Bearing seal question ... - Fiberglass RV
Old 04-29-2012, 09:08 PM   #1
Trailer: 1978 Trillium 4500
Hello All,
I repacked my bearings today. I was surprised that the bearing seal on the interior side of the wheel did not seem to push the interior bearing all the way into the race.
Is this normal?
Also, I noticed that the electric brake magnet seems to "ride" on the surface of the drum, pushed there by a small spring. Is this normal?
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 04-29-2012, 09:43 PM   #2
Deb & Chuck's Avatar
Name: Deb & Chuck
Trailer: Bigfoot (8), Boler, Trillium, ECO, U-Haul, Burro, Escape (3), Trailswest, Compact Jr., Casita, Scamp
Did you wipe grease on the bearing cup in the hub? Then you just lay the bearing cone in the bearing cup and install the seal. The bearing will look loose until you install the hub on the axle spindle. When the nut is installed on the spindle you will not have any loose parts inside. Everything sits in it's place.
Chuck
Deb & Chuck is offline   Reply With Quote
Old 04-29-2012, 10:22 PM   #3
IllAnnoy
The inside seal seals the interface between the hub and the spindle. The inside race on the inner bearing seats against the boss on the spindle.
Old 04-30-2012, 08:01 AM   #4
Did you place grease on the axle part that the seal turns on?
Was the seal flush with the drum after U installed it?
Old 04-30-2012, 08:07 AM   #5
To answer your question, no, the bearing seal is not supposed to hold the bearing in the race. There will be a space between the seal and bearing when it is installed and the tension is set with the axle nut.
Old 04-30-2012, 08:27 PM   #6
Dan Meyer's Avatar
I believe both conditions are normal.
-- Dan Meyer
Wheel bearing question Denece Problem Solving | Owners Helping Owners 21 03-29-2012 04:28 PM
Interesting Bearing Seal Raz Towing, Hitching, Axles and Running Gear 8 05-29-2011 05:03 PM
Yet another vent re-seal question: compact Junior Kent I Problem Solving | Owners Helping Owners 10 06-15-2009 04:18 PM
bearing help please Kelly S. Towing, Hitching, Axles and Running Gear 19 12-31-2006 07:03 PM
Bearing lubes Legacy Posts Care and Feeding of Molded Fiberglass Trailers 12 08-22-2003 07:12 AM
