Bearings - Fiberglass RV
Old 06-03-2014, 12:28 PM   #1
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Bearings
Are scamp bearings proprietary in any sense or are they available places other than the scamp website?
My mechanic was going to help me replace them but his parts guy couldn't find a match.
Something any trailer/rv store should have?
summer scamp is offline   Reply With Quote
Old 06-03-2014, 12:44 PM   #2
Trailer: 2014 Escape 21
Virginia
If you have a #10 Dexter 3500# axle or a 3500# ALKO axle the bearings and seals are pretty readly available. If you have an E-Z lube axle make sure you get double lip seals.
Best to try E-Trailer or Eastern Marine both are on line trailer supply outlets.
The older 2200# axles (4 bolt) should also be available. I think the last set I bought for the older axles was from a Northern Hyd. store.
Eddie
Old 06-03-2014, 01:06 PM   #3
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Hmmm... No clue about my axle. But I assume if I post a pic of it yall help me out. Thanks.
Old 06-03-2014, 01:09 PM   #4
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
I do have this pic... Not sure if it helpsClick image for larger version
Name:	ImageUploadedByFiberglass RV1401822463.585972.jpg
Old 06-03-2014, 01:17 PM   #5
Timber Wolf's Avatar
North Florida
That 5 lug axle should be a replacement, isn't your Scamp an 1985? Maybe look around underneath for a tag?
Old 06-03-2014, 02:18 PM   #6
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Scamp is an '85.... I'm getting under there soon.
Old 06-03-2014, 02:21 PM   #7
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Alko type:s2585 cap:2100
And also some number in the middle that is hard to make out ...
A:29255408002
Name:	ImageUploadedByFiberglass RV1401826883.582794.jpg
Old 06-03-2014, 02:53 PM   #8
FTTRV's Avatar
Trailer: tp
Here is the best way to tell which axle it is. Remove the hub and get the number off the outer bearing cone. If it is 3500# I have the parts in stock if not 3500# I have the parts in stock.
Chuck
Old 06-03-2014, 03:08 PM   #9
Take a set of bearings along with a seal to Advance Auto, Auto Zone, Tractor Supply, Napa, Federated. Any of those stores should be able to provide you with the correct set of bearings and seals.
Having bearings packed tomorrow any other must do's? Robin G Problem Solving | Owners Helping Owners 27 04-28-2015 12:35 PM
wheel bearings thomas kaz Problem Solving | Owners Helping Owners 6 06-15-2009 10:53 PM
Bearings and seal size for 79 Trillium ? Wayne Dirkson Problem Solving | Owners Helping Owners 0 05-22-2009 06:47 PM
Request for Information/Assistance - Wheel Bearings Chuck Dirnsa Problem Solving | Owners Helping Owners 3 05-09-2009 04:28 PM
Question about trailer bearings? FredericL General Chat 6 04-17-2009 01:41 PM
