bed woes - Fiberglass RV
Old 05-31-2011, 09:45 PM   #1
Saskatchewan
bed woes
We enjoy our little camper but...........how we wish the bed was REALLY double size...........or even easier to get in and out of! Hubby is getting a tad too stiff in the joints to climb over me if he needs to get up in the night.
Has anyone come up with a good solution/adaptation etc to improve the sleeping aspects of life in tiny trailers?
Just thought I'd throw out the topic and see if anyone can help.
Hazel in Sk is offline   Reply With Quote
Old 05-31-2011, 09:58 PM   #2
IllAnnoy
Our camper is a Scamp 13 deluxe but maybe the principle is the same...
One thing which we recently experimented with was extending the bed forward between the cabinets. Our camper has been modified to a wraparound couch so we simply used the original table for the extention and it worked great by only shortening the leg.
Here is a picture of our "King" bed conversion...
Old 05-31-2011, 11:17 PM   #3
In our case we don't have an on board toilet. When one of us needs to make that middle of the night trip the takes advantage of that goes along too. That way I don't have to try to climb over my wife. Adaptation is the key to living in small trailers.
Old 06-01-2011, 12:44 AM   #4
Roger C H's Avatar
Smile Our bed solution
My wife gets the large bed and we convert the front dinette for me. Along with the gettng "more mature problem" you mentioned, I was getting claustrophobic with the two of us in that 3/4 bed.
Does your Ventura have a convertable front dinette? The picture in the gallery looks like it is even smaller than our Trillium.
Old 06-01-2011, 09:05 AM   #5
Trailer: 13 ft Scamp
We sleep as Floyd does -- with a bed extension where we place our feet and our heads under the rear window. Tons more comfy!
Darnelle is offline   Reply With Quote
Old 06-01-2011, 11:36 AM   #6
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
Do you then un-do the bed everyday? Our sink area is right where the bed extension would go, so there would be no room to stand and do dishes.
Old 06-01-2011, 11:41 AM   #7
melissab's Avatar
Trailer: 2012 Scamp 13 DLX
WOW, Floyd! That looks soooo comfy! Did you move the furnace from under the sink area or do you just not use it when the bed extension is out? Now see, that would have worked for me and hubby and then the kids would still have the front bunks. Will keep that in mind for the future!
Melissa
Melissa in Florida
2016 Honda Odyssey
melissab is offline   Reply With Quote
Old 06-01-2011, 12:20 PM   #8
IllAnnoy
Melissa
Actually it is both easy to set up and comfy, but we have only used it a couple of times since we have a 54" bed, which is comfy enough for us.
I did this as an excercise to illustrate what could be done with a 13, especially since the only added part needed was the original Scamp table,which I already had in the loft of my shop. The only drawback to this is that I must carry the table in the TV.
We have a heatstrip in our A/C as long we have shorepower.The furnace can not be used in conjunction with the "king" extention and the closet can only open a few inches.
On the plus side, it eliminates the crawl over problem and leaves room to stand in front of the counter and still reach the sink. Remarkably, it really feels like a "king" bed since the narrow section at the foot does not cause any of the problems one might expect.
We have found that a shorter version can give the effect of a wider bed when sleeping in the normal configuration, allowing the outboard person to sleep comfortably without feeling too close to the edge.
Measure yours and make the extension only as long as needed.
Old 06-01-2011, 12:24 PM   #9
IllAnnoy
For the times that we used this configuration we have removed it everyday, since it is only one folding leg and merely sets on the original rails.
Old 06-01-2011, 02:41 PM   #10
melissab's Avatar
How do you secure the extension to the bench so it doesnt slip off? That could be a rude awakening, lol.
Melissa in Florida
2016 Honda Odyssey
Old 06-01-2011, 02:44 PM   #11
IllAnnoy
it sets on the same track as it did originally but only about 22" ,which is adequate to avoid any problem.
Old 06-01-2011, 02:50 PM   #12
melissab's Avatar
So you use it in conjuction with your smaller table for your U-Dinette setup? Which, wouldnt that make your bed smaller than 54" using the home made table without the extension?
Melissa in Florida
2016 Honda Odyssey
Old 06-01-2011, 03:02 PM   #13
Greg H's Avatar
Trailer: 72 Boler American
Indiana
I like it!
Old 06-01-2011, 11:07 PM   #14
IllAnnoy
Actually, my wraparound has an adjustable base under the across section and I don't use the table at all when setting up the "king".
when setting up the regular bed, the table is 22" and the balance is 32", thereby making the full 54".
Here's several thousand words worth...
water heater woes Dan B Problem Solving | Owners Helping Owners 16 08-01-2011 06:40 PM
Water Heater Woes Roger H Problem Solving | Owners Helping Owners 1 10-14-2008 03:22 PM
Furnace Woes Joseph Olajos Problem Solving | Owners Helping Owners 5 06-23-2007 03:23 AM
Propane woes Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 11-05-2002 03:50 PM
