Belly Band Help! '75 Trillium 1300 - Page 2 - Fiberglass RV
Old 07-05-2016, 04:37 PM   #21
Jim Bennett's Avatar
Originally Posted by roy vannoy View Post
Were there any rivets or screws that hold the two fiberglass halfs together?
The two halves were joined together with rivets, through the belly band on the outside, and small plates/washers on the inside. This basically aligned the walls of the two halves close together, and then a layer of fibreglass was added to the inside to give it structural strength.
You can see in this image where I was grinding out the joint on the left to glass over smooth, in order to eliminate the belly band, and to the right, you can see the backing plates with the rivet in them that went through the belly band which has bee removed.
Another couple shots showing the joint.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
trillium
1975 trillium 1300 belly band options? Ptmatt Care and Feeding of Molded Fiberglass Trailers 7 09-23-2015 04:14 AM
Belly band help needed Island Claire Problem Solving | Owners Helping Owners 6 03-24-2015 07:43 AM
Help: Trillium Belly Band msinger919 Problem Solving | Owners Helping Owners 11 11-13-2012 09:35 PM
Belly Band from 1977 Trillium 1300 RixyRV Classified Archives 0 08-17-2011 01:46 PM
