Belly Band Trillium - Fiberglass RV
Old 05-10-2010, 06:53 PM   #1
Trailer: Trillium 13 ft
I want to remove the black plastic part from the belly band of my Trillium 1300. I tried pushing it, pulling it, with and without pliers! I tried from both ends. It didn't work.
Is there any trick to remove it without destroying it?
Johny Bg is offline   Reply With Quote
Old 05-10-2010, 10:39 PM   #2
Trailer: Trillium 13 ft 1976
it gets all old and brittle. i removed mine and had it replaced at an rv repair/dealership. was cheap.
Janet G is offline   Reply With Quote
Old 05-11-2010, 10:48 AM   #3
Mike and Sarah K's Avatar
Trailer: 1979 Trillium 13 ft
New Brunswick
Try putting some heat on it with a blow drier or heat gun (low setting). It will become more soft and pliable. If you do have to replace it, make sure you buy a roll at least 52 feet long to get from door edge to door edge. I bought a 50' roll and ended up 15 inchs short! (not counting the dor)
Mike and Sarah K is offline   Reply With Quote
Old 05-11-2010, 11:45 AM   #4
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Just a heads up, but I've found that this stuff expands in the heat n contracts in cooler weather, so, depending on your thoughts on this, you might want to cut this stuff a little on the long side, especially the piece for the door! You can always re-trim later.....
trillium
Trillium Belly Band Randy Bishop Problem Solving | Owners Helping Owners 9 05-16-2013 05:00 PM
Trillium Belly Band freddie b Problem Solving | Owners Helping Owners 0 05-04-2010 07:01 PM
Fixing the Trillium Belly Band Clark Martin Problem Solving | Owners Helping Owners 21 03-19-2010 09:05 PM
Trillium belly band rivet removal Mike and Sarah K Problem Solving | Owners Helping Owners 14 02-24-2010 02:20 PM
trillium belly band Barry Konkin Problem Solving | Owners Helping Owners 3 01-21-2009 04:13 PM
