Bending the door holdback thing - Fiberglass RV
Old 12-20-2016, 06:52 AM   #1
Trailer: 2004 Scamp 13
Hi All,
Does anyone know how to bend the door holdback on a Scamp 13? We recently bought a Scamp, but the holdback piece is straight and needs to be bent. I have tried using a heatgun and vice pliers but no luck... I just put "teeth" marks on it.
Thanks!
Constan
constan is offline   Reply With Quote
Old 12-20-2016, 07:26 AM   #2
The door hold on our old Scamp and our present Casita were / are flat or in other words without a bend . Using a heat gun you are more likely to damage the fiberglass long before you soften the metal enough to bend easily. If you really want to bend it , then remove the piece from the trailer and place it in a vise and then bend it
Be aware that if the piece is plated you may damage / crack the plating.
Old 12-20-2016, 07:31 AM   #3
Mine is straight too. Hummm. Constan, what is the condition that you believe it should be bent?
Old 12-20-2016, 07:34 AM   #4
Trailer: 2014 Escape 21, Lil Joe
I usually replace the Scamp door hold back arm with the longer stainless brackets. I put the new bracket in vice and lightly whack it with a hammer to get the correct angle before attaching it to a shell.
Eddie
Eddie Longest is online now   Reply With Quote
Old 12-20-2016, 07:46 AM   #5
Steve - Yeah, I realized that so I stopped with the heat gun thing. I really want to be able to do it without having to drill out the rivets, but I think thats the what I need to do. Thank you!
Donna - The door hold doesn't align into the latch, its off about 25 in the straight config.
Eddie - Thanks, I guess thats what it looks like I need to do. I'm just trying to avoid having to drill out the existing rivets.
Thanks guys!
Constan
PS. Thanks for being so prompt with the replies! This board is !
Old 12-20-2016, 08:02 AM   #6
Be aware that placing the hold back arm into the door bracket is not an easy fit. My wife struggle when she attempts to deploy it .
My point is that it is designed to work when flat and if you bend it will you gain enough to warrant drilling it out and then riveting it back in place . Not a criticism just something to ponder .
Old 12-20-2016, 08:10 AM   #7
Steve- got it, thanks! Yeah, I think it will be worth it. One other thing that the hold back arm does is that it prevents the door from opening too wide and then cracking the gel coat & fiber at the hinges. This Scamp already has some wear from over-opening the door. Not sure why they let it off the lot with the arm not working though. Maybe it was replaced at one point and the old owner didn't do his/her homework on the bending thing before it was riveted on.
Old 12-20-2016, 08:56 AM   #8
Jon - Oops the issue is in the center, not at the hinges. The bracket IS misaligned, not sure if it was from the factory or from a previous owner.
images: https://postimg.org/gallery/m3gqmdsw/
Old 12-20-2016, 09:01 AM   #9
the issue
Old 12-20-2016, 09:57 AM   #10
I deleted my earlier post because I figured out what the issue is. When I looked at the part on Scamp's website, it states clearly that the bracket has to be bent before installation. Looks like a PO replaced the bracket and didn't read the fine print. I doubt it came from the factory that way.
I don't know if it is possible to bend it while attached to the trailer without doing damage, but Eddie's suggestion now makes perfect sense.
If you remove it, replacing it with a stainless steel version makes a lot of sense as well. You'll never have to do it again.
Old 12-20-2016, 10:45 AM   #11
Are yall SURE that the door's hinges arent the culprit????? They can do some weird things and if they have shifted, that latch will be off. That's one thing I dont think I've ever seen Scamp boo boo on.
Old 12-20-2016, 11:36 AM   #12
Got it. Thanks Jon. Where can I get a stainless steel one from?
Old 12-20-2016, 11:38 AM   #13
Darral - I don't think it's the hinges, they look like they are normal and they operate normally too (no need to lift door to close or anything).
Old 12-20-2016, 11:49 AM   #14
It was just a "to make sure" gesture. AND to make sure, close the door and stand on the outside and look around the perimeter and the door should be fairly centered in the recess of the Scamp body. Doesnt hurt to check.
If I think about it at lunch, I'll check mine and see if it's bent. Of course depending on where the installers locate it on the door depends where it will hit. Just hard to imagine that hasnt worked since the factory though. Anyway.... interesting find.
fridge door thing ? Bigfoot Alberta Mac Problem Solving | Owners Helping Owners 3 09-03-2016 06:06 PM
Thing 1 & Thing 2 Lenna K Modifications, Alterations and Updates 5 02-03-2016 10:33 AM
Thing 1 & Thing 2 Lenna K Hi, I am.... 5 11-26-2015 02:51 PM
The VERY next thing! Roger H General Chat 12 11-25-2005 11:27 PM
Whats the craziest thing you done to your PC Chester Taje General Chat 24 11-13-2005 01:57 PM
