Best Caulking - Fiberglass RV
Old 07-05-2011, 04:56 PM   #1
Trailer: 1980 Scamp 13
Best Caulking
Hello everyone, I have been lurking here for awhile now and have learned a lot from from all the knowledge and talent that is found here. I would just like to say thanks to all that contribute. I hope I can be a help to someone in the future.
I am in process of restoring my new to me Scamp 13. The PO really did a lot of Jack legged things some of witch involved putting some screws through the sides that are now leaking. I would like to put some sort of sealant on the screw heads for now to stop the leaks until I can remove them and fix it right. I know now from reading here not to use anything with silicone in it because it is the devil. So what is the best thing to use. I hope to eventually repair the gel coat and maybe a complete paint job.
Thanks Brad
Brad M. is offline   Reply With Quote
Old 07-05-2011, 06:22 PM   #2
Raz
Raz's Avatar
Hi Brad and welcome. Are these screws holding something, i.e. in place of rivets used at the factory? If so there are lots of threads dealing with rivet replacement. I would suggest you use the search function and access the experience of others. If on the other hand the screws will be removed and the holes filled, then lots of folks here have had good luck with epoxy putty to fill the vacant hole. Covering the head as a long term fix doesn't work well. Again welcome to the forum, Raz
Old 07-05-2011, 06:38 PM   #3
Yes Raz I will be removing the screws that I am talking about. The Epoxy Putty sounds like it would be something to consider I saw Marian-Tex Epoxy in another thread is this what you where talking about?Thanks for the welcome and the quick reply.
Old 07-05-2011, 06:41 PM   #4
I took the stinky slinky tube off the front of my Scamp and filled the holes with Magnum Marine/Plastic Fiberglass Repair a two part kneaded putty. It's sandable and paintable. But this was for holes, not trying to cover up a screw, etc. I don't know what the screws are holding, but I'd think through a short term solution that may turn into a long term problem. YMMV
Old 07-05-2011, 06:48 PM   #5
Thanks Donna I will check this out also.
Old 07-06-2011, 09:19 AM   #6
Raz
Raz's Avatar
Marine-Tex is one folks like but I have never seen it at the local hardware stores. PC-11 is one I bought recently for a door repair. It's an epoxy paste and will take paint but not gel coat. You will find lots of folks swear by it. JB weld also makes a marine putty. I'm sure any of them will work.
re-caulking roof Tom Byron Problem Solving | Owners Helping Owners 17 11-27-2023 09:40 PM
What type of caulking to use !!!!!!!!& LeeAnne Problem Solving | Owners Helping Owners 16 02-05-2017 11:25 AM
caulking Erin F. Modifications, Alterations and Updates 20 11-13-2013 02:42 PM
Best caulking material? TonyL Problem Solving | Owners Helping Owners 14 12-04-2005 12:35 PM
Removing old caulking Legacy Posts Problem Solving | Owners Helping Owners 9 06-28-2003 08:28 AM
