Best glue for for foam - Fiberglass RV
Old 01-25-2017, 08:06 PM   #1
Hi. Newbie here. I am restoring a nine and a half foot Bigfoot truck camper a window leaked and almost all of the wood went bad. I replaced the floor stringers and foam. I had to strip almost all of the paneling.. I am curious what is the best way to glue new paneling to the old foam insulation. Epoxy? Latex contact cement? PL foam board adhesive? Styrene resin? Thank you in advance. Also, I apologize of other threads have covered this topic
Swiftwater15 is offline   Reply With Quote
Old 01-26-2017, 08:28 AM   #2
Johnny M's Avatar
Deep South
contact cement will eat styrofoam, PL foam board adhesive is probably going to be your best bet. If you choose something else make sure the labeling says it works with styrofoam (polystyrene)
Old 01-26-2017, 10:13 AM   #3
Trailer: Northern Lite
Pl premium works great.Add a spray of water to activate the set.m
milt is offline   Reply With Quote
Old 01-26-2017, 01:47 PM   #4
Trailer: Trail Cruiser
I'm not sure why you would be attaching paneling to styrofoam. Usually, the glue is to attach the insulation and hold it in place and seal the spaces around it. Attaching the paneling to the stringers would be stronger? Some adhesives will melt styrofoam so check the label carefully.
Old 01-26-2017, 02:26 PM   #5
Trailer: G30 Elite Class C
Water Base Glue is what works best or Upholstery glue by 3M
Stude
stude is offline   Reply With Quote
Old 01-26-2017, 02:30 PM   #6
no stringers
There are no stringers in the walls, though there are in the ceiling and floor. The walls are just a sandwich of fiberglass shell, EPS foam and paneling, each layer glued with a pink contact cement.
Polyurethane glue did not adhere well gluing stringers to the floor. I ended up using epoxy.
Old 01-26-2017, 02:36 PM   #7
Originally Posted by stude View Post
:Water Base Glue is what works best or Upholstery glue by 3M
Stude
Have you used the water-based glue for a similar application? I am wondering how well it holds up to heat. I definitely don't want to do it twice.
Thanks
Old 01-26-2017, 02:51 PM   #8
Raz
Raz's Avatar
Vermont
As few years back I insulated my foundation with ESP foam. I bought a liquid nails adhesive designed for the application. It didn't work. I called the 800 number on the tube. The guy that answered the phone couldn't help me so he connected me to an engineering type. After a few minutes chat he decided I had bought a "bad batch" and sent me a case of polyurethane adhesive. Worked like a charm. Not sure why it didn't work for you? Raz
Old 01-26-2017, 03:45 PM   #9
Makes sense David. My bad, I thought you were working on the floor.
Which foam mattress is best for our Scamp? inspector4933 Modifications, Alterations and Updates 22 10-01-2014 07:49 PM
Anyone have experience with NU-FOAM vs Foam for seat cushions? Perseustheegg Modifications, Alterations and Updates 0 08-17-2012 02:20 PM
Best methods to fill holes & best glue Becky B Problem Solving | Owners Helping Owners 19 08-11-2012 08:14 PM
memory foam vs foam rubber mattress Phillip Problem Solving | Owners Helping Owners 11 06-28-2009 07:52 PM
Adhesive to glue foam cushions together? Legacy Posts Problem Solving | Owners Helping Owners 4 03-12-2003 09:37 PM
