Best Paint for Ensolite ? - Fiberglass RV
Old 06-20-2007, 02:40 PM   #1
Trailer: 1972 13 ft Boler
Manitoba
I want to paint the interior of my ' 73 boler (Ensolite).I have removed the seam tape and filled the gap.
I live in Winnipeg,,-35 to +120 degrees.
Which paint is best ?
I understand some members have used ;Tremclad,Melamine or Acrylic Latex.
When my Wife saw the Skull & Crossbones on the can of Tremclad , it went back !!!
Canadian Tire tells me there are 2 types of Melamine,,Oil base and Latex.They recommend the Latex variety.
Semi-gloss Exterior Acrylic Latex sounds like a possibility.
I also have to paint the door interior (Fiberglass.) Do I use the same paint ?
Which have you used and how did it work out ?
Thanks Folks,
Andy H is offline   Reply With Quote
Old 06-20-2007, 02:52 PM   #2
Chester Taje's Avatar
I used melimane oil base on the interior of my previous 17FT Boler.I did not try to paint the inside fiberglass.
Old 06-20-2007, 04:33 PM   #3
Greg A's Avatar
Trailer: 2015 Escape 19
Topic from June 12 covering Ensolite painting.
Painting Ensolite
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 06-20-2007, 05:08 PM   #4
Manitoba
Hi Greg,
yes I saw that post and even contributed to it but I was hoping that there would be more responces ,especially from the colder weather zones.
Old 06-20-2007, 08:15 PM   #5
Greg A's Avatar
Hey Andy,
We're the opposite, eh? Need to withstand 110 degree heat.
We've been out for 2 5-day trips so far with the renovated Scamp and we're having no issues with paint chipping or flaking off.
Good luck with your project and can't wait to see some pics.
Owner:
Old 06-21-2007, 08:02 AM   #6
Barbara Gardin's Avatar
We painted the complete interior of our Boler 5 years ago with oil based melamine cupboards ensolite and all. It still looks like it was just done.
Barbara Gardin is offline   Reply With Quote
Old 06-22-2007, 06:25 PM   #7
Manitoba
Well after pondering the problem for some time,I decided to go with a 100% Acrilic Latex Kitchen & Bath mould resistant paint.
Just put on 2 coats and it sure looks good.
If it ever stops thunder showering long enough to let it dry well,I can put everything back in and bask in the glow of success !
Old 06-22-2007, 06:30 PM   #8
Old 06-22-2007, 07:15 PM   #9
Greg A's Avatar
Pics Andy, Pics...
Owner:
Old 06-23-2007, 04:36 AM   #10
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Andy... I hope you used "EGG SHELL" finish Alf S. North shore of Lake Erie
Old 06-23-2007, 10:33 AM   #11
Robin H's Avatar
Trailer: 73 13 ft Boler / 2004 Toyota Corolla
Send a message via MSN to Robin H
Hi Andy,
Did you paint the fiberglass door? I started painting my 73 boler yesterday with a latex kitchen and bath paint. I plan to do the door as well as inside the cupboards. I did a test area in the closet and seems to be just fine.
Robin
Robin H is offline   Reply With Quote
Old 06-23-2007, 11:31 AM   #12
Manitoba
Yup,I painted the Ensolite,insides of the door,cabinet and cupboards.
So far so good !
Old 06-24-2007, 02:00 PM   #13
Robin H's Avatar
What did you use to paint it with? I have found a brush vs roller works best but very time consuming. I finally finished the first coat last night and am dreading another coat but it needs one. Some areas I used a paint brush but it sure takes a long time. Other times I switched back and forth from foam roller and regular roller. Not sure what I think about that. Does not fill in as well and is messy as far as splashing....
Any words of wisdom from anyone to make the second coat of paint less painful on me???
Thanks,
Robin
Old 06-24-2007, 02:21 PM   #14
Manitoba
Hi Robin,
I used a regular roller on the large areas,a short high density foam roller in the inside corners and a brush as required.
The first coat took much more paint than the second as it got sucked up.I didn't do a 3rd coat as it looks good after 2 and almost finished off the gallon.
I think you'll find the 2nd coat easier to do than the first.
We both have White/Green bolers.
Are those car tires ? What size ?
Andy
paint, painting
Ensolite Donna D. Care and Feeding of Molded Fiberglass Trailers 22 10-23-2009 06:02 PM
To remove or just paint ensolite ursulap Problem Solving | Owners Helping Owners 11 07-04-2009 05:43 PM
Ensolite - where to buy? Erik J Problem Solving | Owners Helping Owners 2 02-05-2009 04:21 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
Ensolite paint Dan Simon Care and Feeding of Molded Fiberglass Trailers 23 04-06-2006 10:12 PM
