best way to fix these massive rips in closet - Fiberglass RV
Old 01-23-2011, 12:16 PM   #1
Trailer: 74 boler
hey guys
getting almost done with the project just fixing a bunch of small things....wondering the best way to fix these big rips and tears in my closet. Ive glassed it back together in the back, but wondering the proper steps for the front....going to paint them a different colour so i'm trying to get this all figured out......check it out
thenoob is offline   Reply With Quote
Old 01-23-2011, 12:32 PM   #2
Trailer: 74 boler
sand
body fill
sand
paint?
if im correct, then what is the best way to get everything "flush" again because at the tears, although ive glassed them together in the back, there is still a gap between them in the front
Old 01-23-2011, 01:13 PM   #3
james kent's Avatar
Trailer: Boler 1984
I would grind or sand everything flush and then add a layer of glass and then repeat the sanding before painting. Glass on the back and glass on the front would make it a very strong sandwich.
Old 02-01-2011, 07:46 AM   #4
Trailer: 13 ft Scamp Deluxe 2007 and 40' Allegro Bus
Iowa
Send a message via AIM to RSchleder Send a message via Yahoo to RSchleder
If I understand correctly, the back side will show as well as the front side when completed? I'd add the fiberglass cloth on the backside only and use the epoxy filler mix on the front side that shows more than the back side. You'll need the cloth for strength so the best you can do is put it where it'll be the least visually objectionable. Good luck, Ron
RSchleder is offline   Reply With Quote
Old 02-04-2011, 12:06 AM   #5
Trailer: Own a PUP and looking for a Boler
For something non-structural like that I would grind away the loose stuff on the back side and glass the back side with 1oz mat and GRP polyester resin.
Then grind out the front down to the new material you applied and do the same to the front.
Grind and finish sand both sides to the required thickness when all is cured.
Start with small width strips and make them wider to build up the v-grove that you have ground out and do not cut the mat with hard edges. Tear them by hand and feather them.
If done properly very little bondo or any other kind of filler should be required.
brslk is offline   Reply With Quote
How to fix anything on an RV site d_wildemann Problem Solving | Owners Helping Owners 1 10-23-2007 03:53 AM
More useful closet Isaac M Modifications, Alterations and Updates 2 07-15-2006 10:52 AM
Leak FIX, PLEASE rickster Problem Solving | Owners Helping Owners 15 03-30-2006 08:26 AM
website fix Lew King General Chat 1 11-17-2005 12:10 PM
Dont fix it Legacy Posts Jokes, Stories & Tall Tales 2 11-27-2002 12:40 AM
