Best way to get gum out of carpet? - Fiberglass RV
Old 07-20-2007, 11:10 AM   #1
Trailer: 1998 17 ft Casita Spirit Deluxe / Red F150 X-Cab
Another thing I learned this last trip...if you stop in a parking lot, check your feet before entering the trailer. I tracked in pink bubble gum and, of course, dirt is stuck in it and it is a mess! Has anyone had experience in getting gum out of low nap Casita carpet? Thanks!
Lisa M. is offline   Reply With Quote
Old 07-20-2007, 11:39 AM   #2
Sandra Lair's Avatar
Trailer: 1982 Scamp 13 ft
Lisa,
I hate when that happens! I've removed gum from other low-pile carpeting by using ice to freeze the gum, then scraping with a knife blade. It hasn't happened in the Scamp yet but I've done this at home.
I've also read that you can use WD-40, Goo Gone, etc. but I've never tried these. I'll always been afraid it would leave a stain and/or odor.
Good luck!
Sandra
Sandra Lair is offline   Reply With Quote
Old 07-20-2007, 02:40 PM   #3
Al Stansell's Avatar
Trailer: 1976 13 ft Boler and 1980 Trillium 5500
There are several products that are specifically designed to remove gum from carpeting. They are aeresol products that freeze the gum and then it comes right off. Just about every custodial supply house makes a version and they all work. WD-40 and Goo Gone will stain your carpeting!
Cheers, Alec
Al Stansell is offline   Reply With Quote
Old 07-20-2007, 04:40 PM   #4
pjanits's Avatar
Trailer: 17 ft 1986 Burro
Like Sandra said.
My Father in law, may he rest in peace, always used to freeze the gum with ice cubes, then it just popped off when you scraped it.
Old 07-21-2007, 01:05 AM   #5
Like Sandra said.
Thanks, everyone! I'll try the cheap and easy route first, the ice cubes, and if that doesn't work I'll hit the hardware store. I've heard of using ice cubes (and peanut butter, but felt that was a bad idea) for getting gum out of hair. I guess it holds true for carpet too. Thanks again!
Old 07-24-2007, 12:19 PM   #6
V'sGlassSleeper's Avatar
Trailer: 1988 Bigfoot Deluxe B19 19 ft / 2007 Nissan Frontier V6 NISMO 4x4
Peanut oil works like a charm to get out chewing gum. So if you have a container that hasn't been opened, you need only use the oil, don't mix in all the solid. Then you can use any degreaser to get the oil out UNLESS it's polyester or other petroleum-based carpeting--in which case, never use anything oil based on it... it will never come out (oil attracts oil).
Good luck!
V'sGlassSleeper is offline   Reply With Quote
carpet needs to go Ricky 4 Problem Solving | Owners Helping Owners 3 07-11-2008 05:50 AM
Carpet vs Ensolite Paula Bindrich Problem Solving | Owners Helping Owners 10 08-24-2007 05:36 AM
new carpet Terry G. General Chat 2 11-13-2006 10:15 AM
new carpet Legacy Posts Modifications, Alterations and Updates 15 04-08-2003 08:55 AM
New Carpet with Photos! Legacy Posts Modifications, Alterations and Updates 2 10-02-2002 06:42 PM
» Trailer Showcase
Lilly
Antonia
Bigfoot
Dot G
