Best way to seal screws in shell? - Fiberglass RV
Old 08-06-2016, 09:09 AM   #1
Patricia D.'s Avatar
Trailer: 1975 Ventura
Manitoba
What is the best way to seal screws that penetrate the fg shell?
On hand I have: Sikaflex sealant, Tech plastic, spot putty and resin.
Will any of these work?
I am hoping not to have to make a special trip to the store but, on the other hand, want to make sure I stop water so will buy something else if necessary.
Thanks.
Patricia D. is offline   Reply With Quote
Old 08-06-2016, 09:25 AM   #2
Trailer: Compact Jr and Teardrop Trailer
I used rubber bonded washers. That is what my trailer originaly had. I found them at Lowes. They come in #10, #8, #6 an 1/4".
Jeremy
rainjer is offline   Reply With Quote
Old 08-06-2016, 10:25 AM   #3
I owned various fiberglass sailboats for many years and I always used sikaflex or 3M 5200 for such things. Both products work very well.
Dave W. is offline   Reply With Quote
Old 08-06-2016, 01:09 PM   #4
Trailer: 2008 Casita 17 SD
+1 on the Sika-Flex. It's my sealant of choice as well.
3M 5200 is also a very good sealant, but the downside to using it is that, when applied, it creates a virtually permanent un-releasable bond. If you want to use a 3M product, I'd opt for the 4200 instead of 5200, unless you never ever want to take whatever you're bonding apart again.
Old 08-06-2016, 03:04 PM   #5
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
A little dab of silicone calk, either clear or white, is all yoou need.
Old 08-06-2016, 03:10 PM   #6
You are right about the 5200 Greg although for screws I've not had a problem with getting them out. 4200 would be a better choice though.
Old 08-06-2016, 05:00 PM   #7
Manitoba
Thanks
I went with the SIka-flex since I had it anyway and it was recommended. Thanks. One more job down.
Old 08-06-2016, 06:53 PM   #8
Trailer: Researching Options
Kentucky
How does Dicor compare to SikaFlex
I haven't used either product yet. I've read good things about Dicor and purchased some of it to use when installing a MaxxFan. Is SikaFlex a better product for this application?
Thanks!!
Bernie
BernieK is offline   Reply With Quote
Old 08-06-2016, 06:58 PM   #9
Kentucky
Are Screw Caps or Snap Caps needed?
Forgot to include this in my earlier question! What is the Forum's opinion on using Screw Caps, also referred to as Snap Caps, for covering screws on the roof or even on the sides?
Thanks again,
Bernie
screws holding shell to frame Sue and Henry Problem Solving | Owners Helping Owners 12 09-21-2015 06:09 PM
7 way plug to 4 way plug back to 7 way plug immrbill Problem Solving | Owners Helping Owners 3 08-10-2015 11:08 AM
Painting the outer shell - the frugal way...? Andrew GPSMapNut Modifications, Alterations and Updates 30 05-30-2011 09:10 AM
What's the best caulk to seal windows?? Mary Lynn K. Problem Solving | Owners Helping Owners 9 04-22-2009 09:03 AM
Need a Quick and Dirty Way to Waterproof Fiberglass Shell! April Care and Feeding of Molded Fiberglass Trailers 13 04-11-2008 03:42 PM
