Better latch on Scamp bunk supports? - Fiberglass RV
Old 06-01-2014, 09:55 PM   #1
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
I am looking to improve the latch system that holds up the front bunk. That piddly little screw into that thin plywood doesn't exactly instill confidence! Are there examples of better solutions? I searched and almost all of the posts are about the factory posts and what they look like. I can weld but I do take the bed down every day so large permanent frames aren't really what I am looking for. I am envisioning some better locking mechanism attached to the original pole. Anyone have a good idea? Thank you.
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 06-02-2014, 10:55 AM   #2
Timber Wolf's Avatar
North Florida
While I was washing the cover and had the plywood out of my front bunk anyway I installed two T nuts in it. I put them one inch over (outboard) from the original screws. My idea was that for a more permanent installation I could put a couple of bolts through the original posts that could not be kicked our bounced out. I have since built a different system (a 5 wide extension the full length of the bunk) that uses door hinges out near the ends so have done away with the factory posts altogether. The T nut idea would work fine with a couple of wing screws for quicker set-up and tear-down.
need better door latch for burro fred wark Modifications, Alterations and Updates 3 02-25-2014 04:54 AM
Scamp bunk supports Newbie Problem Solving | Owners Helping Owners 1 04-02-2013 07:18 PM
Bunk Supports in Scamp 13 barryra Problem Solving | Owners Helping Owners 7 08-13-2010 12:59 AM
Bunk pole supports at base Mike Montville Problem Solving | Owners Helping Owners 7 04-01-2008 10:23 PM
It just gets Better and Better james kent General Chat 5 11-26-2006 12:48 PM
